Ive got me block on the engine stand all nicely rebuilt, but i want someone to educate me on what improvements i need to make on the breathing system. Currently its all standard which i understand is not good for a engine thats going to be 380 odd bhp.
There is a 17(i think) bolt below the turbo in the block to breathe from, and the sump can be drilled, tapped and a fitting added to return the oil, or it can be returned to the sump plug if thats easier,
Lol in the conservatory looking at that bolt as you fone blepped. It's fooking tight. I'll get the impact wrench out tomorrow.
as said breath from both sides of block dont bother with cam breather and return to sump either to sump plug with banjo bolt or have a connector welded on thats how mine is 405 bhp works nice
if you get a gated sump baffle and your engine is on an engine stand be careful if your fitting the sump with the engine upside down as the gates wont be where they should be when you roll it back over!
How are you buddy? Post up you pics on my p100 picy thread
Are these a good idea, ive heard of so many melt downs because of these failing?
