2wd No spark,No live to Ecu
I've got a project 2wd cossie with no spark and theres no live to pin 20 on the ecu and the fuel pump doesn't prime when the ignition is turned on.Theres 12 volts on pin 30 at both the yellow relay plugs in the passenger footwell but the relays don't switch when the ignition is turned on,I've tried both the relays in my running car and they work.When you bridge a wire between 30+87 on the relay plugs then the pump will prime and the ecu will show 12v volts at pin 20 on the ecu??? Has anyone had this problem? There isn't an aftermarket alarm/immobiliser fitted to the car.
The car did run but one day stopped and i found a melted live (red) wire at the ignition switch so replaced that and the wire.
Any help is appreciated as its doing my head in now......
I'm talking about under the dash right? The black wire on the plug 4 other wires needs a 12v it needs to be switched otherwise the car won't stop when you turn the key off. If you have power there it should switch the fuel pump/ecu and injectors.
yeah the black wire behind the dash where the car loom meets the engine loom.Theres nothing there with the ignition on,is that switched by the ignition switch I take it? but what wire is that on the switch??
Although I diden't think 2WD had them, mine certainly hasn't!
Martin
If you look on that big turbo site
All sierra cosworth models used a loom which was separate from the car loom, so it is easy to remove it and use in a different application. The 4x4 L8 differs from the earlier ones in that it is a two part loom with an engine section and a scuttle to ecu section allowing the engine to be removed with its loom still attached. On all types there are basically just 5 wires to connect up :-
ground = brown
battery = red or red/blue
ignition switch = black
fuel pump = black/red
rev counter = green
The brown/green wire is not required as it is for the fault light relay on the L1 or the air con on the L8.
I've not found an factory immobiliser on any 2wd I've broken but I have found on a 4x4.
UPDATE: After a long chat with Tony@Turbosystems i've now got live on the ecu and the fuel pump primes and 12v at the coil! have done the check sheet that I found on here and haven't got an AC voltage on the crank or phase sensor when cranking?? I take it the white plug goes to the white plug on the crank sensor? then theres 2 black connectors left, ones a test and the other must be phase sensor? I've buzzed them out with a multimeter to check continuity while the loom was out of the car.
P.S Tony@Turbosystems is probably the most helpful bloke ever! Cheers Tony!!
after alot of head scratching today i've replaced the phase sensor plug+wiring and now i've got a spark! Had 700ohms at the sensor then as soon as i attached the loom plug to it,i'd check between pins 5+23 and there would be nothing....so replaced the plug and ran two new wires to the ecu and i've got 700ohms and a spark!!! Gotta charge the battery 2nite as its dead then i reckon it will start tommorow,Thanks everyone for the advice!
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
