MSD wasted spark,HELP!!!!!
Hello to all,i would like to ask here about my used MSD wasted spark kit,so i bought one and working fine when removed,so today i finished the install,but the car does not work,i have fire when i turn the switch onthen nothing,also the red wire in the coil plug have current,my car is 2wd with L8 ecu,and it running perfect with the coil gr.a,also the two wires for pin 21 and 26 was unmarked and i tested the 21 with the Multi-Tester in the Wasted spark loom plug and i found it which one is the 21 , also my ignition is unmarked,and here my ecu connections with the MSD wasted spark driver,so does anyone know what is the fault please? thanks in advance
Regards Thanasis
photo upload
picture sharing
photo sharing
Regards Thanasis
photo upload
picture sharing
photo sharing
On motorsport-development's site I saw on a photo that purple and blue cables are reversed.
Check the following link (there is a slide show):
http://www.motorsport-developments.c...tedspark.html#
I believe that you will have to send an email to Motorsport Development to find out the correct connections.
James from MSD is a member on this forum, soon when he read this post will reply to solve your problem!
Hi mate, this is what Stu tol me in 2009 when i had issues with my board
Hi Paul,
To test the drive circuit, do as follows:
1) Unsolder the purple and blue wires and insulate them.
2) RECONNECT the cut legs on pins 25 and 26 to the mother board.
The ECU will now run in normal configuration again when you reconnect the original coil and ignition amp wiring.
Getting a faulty driver isnt totally impossible of course but we have only ever had one faulty that I recall so its not common. Most common is bad soldering but people also often get a loom from someone other than me and its not wired the same as mine but thats usually rectified by swapping plug 1 with 2 and 3 with 4.
I have a second hand MSD wiring loom as well, it has 2 white wires but i can not tell which one goes to pin 21 and which goes to pin 26, is there any way of testing the wiring loom to find out what is what?
yes i found the 21 pin with multimeter,so put the one terminal from multimeter to msd wiring loom male plug the first pin from the left (are four pin together),you can confirm that with the original female amplifier plug,the GREEN wire!!!
Thanks
ive just been soldering the wires into my l8 ecu also with this kit, ive still got to solder the grey and purple, was unsure about cutting the pins part of the instructions but i can see now that it is right to cut the pins, my msd wiring loom is labeled which is 21 and which is 26, so only have to link them into the loom, wont have my engine ready to start for a few weeks yet but ill let you know how mine goes
I fitted one to my 3 door went fine, started first time and even the rev counter worked fine which I understand is hit and miss with 3 doors, defo one of the best things I have done to the car. Only issue I had was finding neatest place to fit the coil pack, ended up with it where original coil was. Not perfect but best place I could find.
I'm useless with a soldering iron in fact James can comment on iron i have here it's rubbish so i just payed the little money to them for a mega neat job.
My 3dr rev counter works fine too i don't understand that either and again as above mines been in since 2009 and it's still performing the way it should, in fact i have had to buy a sensor since i fitted this kit
You can see the cut pins here too.
I dont have a pic of the back side of the ECU to hand, but the red,black,white,pink and yellow wire do not connect to the top side.!
yup i realised last night i had done mine wrong, ill send mine into you to sort, my soldering iron is crap and so am i lol, i sent an email to the email address on the msd website, shall i send it in to the address on msd website and who do i send money to?
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
DixieTheKid
14-09-2015 09:04 PM
