Removing the flame trap and keeping the kidney box on a cossie (Revised)
I have a spec R breather system on my car with the catch tank and all that nonsense, but there is a problem with the kidney box.
The hose from the new breather attaches onto the original kidney box pipework and it seems to be leaking vapour out of it and oiling up my engine bay.
Can I remove the kidney box system all together and does anyone have any photos or tips of how to go about this?
Thanks for the input, i'll look into the wrc breather tank.
it's not leaking at the block it's the plastic pipe just under the inlet, i think it''s the flame trap part, it''s red and black and pushes together, i was going to rip the whole lot out.
Ok I need to understand this photo...!
The pipe on the right of the pic, does this go to the inlet? if so and i'm removing the flame trap, what do I put in it's place, have people blocked it off or what?
Also is there a hose that goes to the sump from either the hidney for or this breather?
(I know the long hose at the top goes to the airbox, and i think the black plastic part is what joins onto the kidney box?)
You blank the one way valve that is screwed into the inlet manifold.
On a 4x4, the sump has a pipe you connect the oil return from your breather to. I don't think this pipe is there on a 2wd? Could be wrong about that though!
matman
09-09-2015 05:45 PM
track.focus'd
12-08-2015 05:53 PM
CabrioTurbo
01-08-2015 11:04 AM
