cosworth overboost
cosworth overboost
hi im having trouble with a misfire at about 5-6k somtimes pops and bangs i think its overboost as boost gauge goes nuts but when i unplug the amal valve the car runs sweet but i was told if you unplug the amal it should half the boost but it boost 22psi with amal valve unpluged but runs perfect im sure the amal is just bleeding all the air off when plugged in and iv tried a diffrent amal valve and it did the same what would cause this could it be the atc sensor?
all hoses seem fine also you cant adjust boost with actuator for some reason but could adjust it with actuator before so i think its all conected could the map sensor cause this
actuator is forge and iv tried to diffrent springs init and still the same also forgot to metion somtimes when left ticking over for a while when i pull away it struggles to get even 5psi of boost then 2mins up the road it goes back to normal
the actuator rod is just slipping over wastegate so as loose as can be also adjusting this doesnt change boost atall also its a forge actuator iv tried 2 diffrent springs and if i run pipe straight from compressor to actuator it boost around 16psi
It sounds like you have a -34 actuator fitted, which should open at around 14 psi when it's connected directly to the turbo.
When everything is working correctly and you remove the connector from the amalvalve it should go back to the standard actuator pressure I think. So that means that with the amalvalve plug disconnected it should also do the 16 psi. If yours is doing 22 psi then the amalvalve must be bleeding some air out, or there is a leak somewhere. Are the 3 ports on the amalvalve connected to the right parts? They are marked, W - Wastegate, R - Recirculate (bleed), C - Compressor. And what about the jets in it?
it does seem like amal is bleeding even when not connected but iv also tried a diffrent aqmal and it did the same it was all fine till 1 day i went shopping come out and had lost all my boost due to split dv so replaced that and ever since had overboost
Adam Graham
06-09-2015 06:04 AM
