Yea I've also heard that side to side play ain't that bad. I think there is just a bit of side play in a completely new turbos, not much though. But if theres longitudinal play and it makes rattling noise when you move the shaft, then it should be ready for change or repair. This is how I've been told.
There maybe nothing wrong with it though, as already said side to side is OK, as when running it runs centrally on the oil pressure. Front to back is where the wear occurs.
Is there any smoking to suggest turbo wear ?
