A strange one, Please help!
Hello everyone
The problem i have is that the car is running cold.
I have a 2wd saff cosworth and around 2 months ago i had the head gasket done.
I changed it with a group a headgasket and a cometic head set. re 'lapped' in all the valves and changed the stem seals, plus new head bolts. i also replaced every sensor on the car and done the cooling system. on the cooling system i replaced every coolant hose, water pump, thermostat and seal, uprated fan swtich and braided fan loom.
I also done cam belt kit too.
I just wanted the piece of mind that the car was ok.
now the car was running fine and never missed a beat. I have done over a 1,000 miles since the work was done.
it started last night on the way home from work the car was fine till i pulled at the lights and a subaru pulled next to me at the lights. Ok you know what happened next, I wasn't going to be beaten by some 'jap crap' so i done him and we had a little play for a few miles. after that i was making my way home and noticed that my temp gauge was sitting in the 'cold mark' the whole time i have used the car it have always been in the 'NORM' so nursed it home and left it on the drive to let idle, then the temp went back into the 'NORM'.
So thought maybe it had a little fit! so checked again this morning and went for a 10 mile drive. all the time driving the gauge was sat in the cold mark. the heating was warm is but cold enough to know the car is running cold still. so again went home and left to idle, went back to 'NORM' but when you drive it it goes back to the cold. checked the rad it it was warm all over, so my thought is that the thermostat is stuck open but how can it be when its only 2 months old. I grabbed the hose and it was cold ish and when left to idle it did open in time. I use the car as a daily driver so its not like it doesn't get used.
Some help to try and point me in the right direction would really help, or if someone has had the same problem. I have tried a search and not found anything.
I'm sorry too if my spelling is not the best but i do try
Thanks
Thanks
Out of many, we are one.
Edit: just seen you already know that! But yeah, might just be a dodgy batch..
sounds like thermostat to me
when i got my car i had no thermostat at all i could leave it static for an age and it would be fine but if i drove the car about the temp would drop off the gauge thanks to the alloy rad replaced it ( at a cost of Ł60+ ) for a 4x4 one and its gleaming now
Check to see if the hose after the stat is getting warm not long after starting the car, if so then you know the stat is stuck open. The pipe after the stat should stay cool until the car is up to temp and the stat opens.
Thank you all for your help.
The rad is standard but if it was blocked in anyway would the car overheat not run cold.
I think what I will do is pull that stat housing out tomorrow and see if it's open.
Starting to bug me now
Have u checked the wire hasn't come off the tempature sensor I'm sure the gauges in the car run off a different sensor to the ecu could have just slipped off as its only a bullet connector type thing, think on a 2wd head its by the turbo water feed on a 4x4 it's under the inlet next to the ecu coolant temp sensor worth a look anyway
Martin
Resident Wrestling Legend
change the temp sensor first to make sure that the guage is reading correctly
if the stat is ok i would check the heater matrix next as if this is blocked it will seem that the car is not getting hot when in fct the pipes aren't doing anything
check the pipes are hot on the bulkhead to and from the matrix
Martin
But the gauge could be faulty due to the sender (ford senders tend to be a one time overheat o ly before they see replacing in my experience) and if the heater matrix is blocked it could give the impression that all is not right even if everything is working under the bonnet
SIERRA RS 4X4 COSWORTH
On your 4x4 the temp sensor is under the collant sensor ....use a gen ford one if you replace it .... they can fail ...
Seen 4x4 stats break in half if the back washer sticks to the housing ...
cheeRS Carl
cheeRS Carl
Got the problem sorted
I took off the stat housing to find the clip in place but the thermostat had some movement. So i removed the clip and thermostat, to find that the rubber seal had moved away from where the thermostat sits and that half the seal had moved away from the lip and was sitting in the elbow. so the water was passing around the thermostat. i'm not sure how on earth the seal managed to move away but when i placed it back i put some sealant around the seal and re fitted the stat. all seems fine and is running to temp perfect. so a cheap fix for me but i hope it doesn't happen again.
Thanks again for all your help
