standard alarm in sapphire
Old 30-12-2012 | 09:10 AM
Marc sierra's Avatar
Marc sierra
Default standard alarm in sapphire
When the alarm is engaged, should it disengage when you open the boot using the key? Mine doesn't, which means the alarm goes off every time I forget to unlock the car before opening the boot. Very annoying.
Old 30-12-2012 | 10:32 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Unlocking from the doors only mate
The trigger look is connected to the door locks so you actually need to turn the barrel to arm/disarm the alarm
Holding it locked also does stuff on the later models with the light and the higher spec models are exactly the same as the lower spec ones as they all use the same door open switches
Old 30-12-2012 | 10:46 AM
Marc sierra
So this behaviour is standard? How annoying.
Old 30-12-2012 | 11:24 AM
dojj's Avatar
dojj
yup, afraid so
there is a way to disable it, but then you can't work the rest of the alarm either, maybe i should restrict this to pm's
tib2220
14-09-2015 12:33 PM
Iain Mac
13-09-2015 09:16 PM
Tony W
09-09-2015 12:08 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: standard alarm in sapphire
