Adjustable Valve
21-11-2012 | 10:04 PM
Adjustable Valve
On my 2wd there is a brass type adjustable valve on the hose line between amal valve and turbo? Is this known as 'bleed valve' ? What does it do, and how do I check that its set correctly?
21-11-2012 | 10:18 PM
get it remove & properly set up, its a bodge way of controlling boost.
assuming its modified, what the full spec of your engine and what chip does it run?
21-11-2012 | 10:22 PM
Don't fiddle unless you know what you are doing. more boost = blow engine if not set correctly= expensive
22-11-2012 | 05:38 AM
Some people like these valves others dont.
22-11-2012 | 06:00 AM
Quote:
Cheap skate people yes... There's countless engine killed.." Death by bleed valve "
22-11-2012 | 08:19 PM
Can this bleed valve be used to replace amal valve, or is it normally used in conjunction with it?
01-11-2015 07:53 PM
Fezman1
02-10-2015 02:22 PM
DAZZER
30-09-2015 09:43 PM
fordrallycar
30-09-2015 08:57 PM
IainRS1700T
25-09-2015 07:44 AM
