4x4 Cosworth original heat shield refurb?
Hi All, I am just about to complete purchasing an OE Sapphire Cosworth 4x4 heat shield which has sadly started to deteriorate at the section which sits above the exhaust. Is it possible to repair the damaged areas? I would really like to know what the shield is made out of...fibre glass, resin?? so that I can use material this to cover the affected areas, sand down and then repaint the whole shield....I will then use a reflective material to give the shield a better shot at survival! Is anybody able to shed any light or has had experience of doing the same? Thanks very much in advance
Thanks for the replys but the heat shield is the black one that sits over the top of the turbo, trouble is the end which sits near the exhaust has a tendancy to melt which is what has happened. I can't decide whether or not to cut out the rot, protect whats left of the underside or use a heat resistant resin and rebuild the damaged sections with new fibre glass...I'm just worried that if I do this the fibre glass might melt?!? -any body had any experience of doing this type of refurb?
I've researched this a bit further and found that the type of resin which binds the fibre glass is what dictates the temp it can withstand once set. Think I'm going to see if there is a suitable off the shelf resin that can cope with exhaust/turbo heat...failing that then its going to have to be the case of chop out the rot and make do with what is essentially a 20 year old shield but as original as they come! Thanks for the help!
Right, after many weeks of faffing about looking into this it doesn't look like anywhere sells the resin I would need. Sadly the heat shield I bought was worse than I imagined (crack down the middle section) therefore its going on the bay as somebody might make use of it but I now need to find a heat shield elsewhere, trouble is they're soooo expensive...anybody know of anybody who can supply something thats up to the task but won't cost £200+? Cheers
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
