Where can I get power steering pipe
09-12-2012, 04:36 PM
I snapped my power steering pipe today right on the banjo bolt from the pump on my 2wd saph any one got one or know where I can get one cheers
09-12-2012, 04:44 PM
cossie fan (unluckerly)
I did the same but brazed mine back together
09-12-2012, 04:47 PM
Ok might look into that its right where the pipe meets the banjo pice cheers
09-12-2012, 04:52 PM
Same as mine did but mime kinked the pipe I had to chop a bit out and braze a bit in as a second hand pipe was over 40 pounds! If you was in basingstoke I'd do it for you mate
09-12-2012, 05:00 PM
I'm in rickmansworth so ur bout half hour away ill get pipe off in the week an give you a message if I get stuck cheers
I did brase mine but it kept breaking,
so I bought Mine from Ford about 2 years ago sometimes it worth to go to main dealers still might have the parts, obvi might have to be oreded
09-12-2012, 05:02 PM
Quote:
Originally Posted by
arse end happy
no worries
10-12-2012, 07:13 AM
10-12-2012, 10:37 AM
It's the other end that snaps off though, at the pump. I've snapped 2 before.
cheeRS
10-12-2012, 11:17 AM
Which pipe is that?
In my second last photo, the top hose joins onto the pump.
10-12-2012, 07:19 PM
Where do you get the pipes an conecters pirtek
10-12-2012, 07:24 PM
Yup hoses from Pirtek, the connectors on the rack I got from MK on here.
tankybaby66
06-02-2016 02:24 PM
Cosnada
07-01-2016 05:30 PM
Fudgey
21
30-09-2015 06:19 PM
deathrider666
28-09-2015 06:12 PM
mpilk
27-09-2015 09:21 AM
