Sierra spoilers question
Hi all, just wondering if a cosworth spoiler from a saff will fit on my XR4X4 boot as I am de wipering it and the spoiler on it atm is bent and has the wiper cut out.
From what I understand it will but will require notching for the rear wiper. If you didn't want to do that then you could either shift it back a little bit or add shims under the legs to raise it off the bootlid a little higher and clear the wiper.
Edit: having just read your initial post properly, yes it should but will need the bootlid drilling and riv-nuts putting in as the cossie spoilers are a bolt through type, not studs like on the standard (later) xr4x4 ones.
andrewmctiernan
08-09-2015 03:05 PM
chris m1
07-09-2015 08:02 PM
Adam Graham
06-09-2015 06:04 AM
