What is best to underseal my car??????
I'm goin to do the underneath of my 3dr replacing any rust e.g but do you need to primer first or anything an I was going to use bullet rust but what do you reckon is best an after it I want to give it a quick paint so its white aswel???? thanks for the help
get a little hand held sand plaster (ebay) blast any serface rust then any bare metal you want a coat of etch primer, then primer and finish with your white paint. if you want a quick job then a quick wire brush down and plaster everywhere in wax oil mix it with engine oil and it will stay wet, will pertect it alot beter than paint and it gos in all the hard to get to places.
so you reckon POR15 do you primer first an what primer? an is it paintable ive got a wire wheel on a grinder an a sand blaster but havent used it yet. As its cold out some should scrape off then fin with the wire wheel. Its goin on a spit to do this so its easyer. Thanks????
por 15 is for bare metal as said in other thread ,so thats bare metal it coat every were with it either with a spray gun or a brush ,let it dry use a good stone chip not shuntz or waxoil ,then paint what ever colour you want on top ,job done should last the car out ,also buy or make a spit its far easier
I've bought a spit its made out of to engine stands. Who I had it off a boy who used it on his Capri just gota make it fit my car now. After using the por15 use like bullet rust over it is it???
steerfromdarear
28
29-01-2016 06:14 PM
