cosworth fuel pump
Standard is normally fine, but for that power level you may need a "group a item"
More importantly have you rewired it, if not then you need to get this sorted, otherwise you risk loosening your engine anyway, it's a well known problem as the wiring builds resistance and hence the pump cannot draw the power it needs, that could be what you are noticing.
Martin
Martin
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
