Idle control valve
Idle control valve
Can anyone please tell me if this is a serviceable part and how is it removed as my Cosworth now idles at anything from a 1000rpm to 4000rpm. If I disconnect the idle control valve, it then seems to run fine.
Many thanks in advance.
Idle control valve
Have not jet washed or steam cleaned the engine. Have cleaned the connectors with wd40. It seems to work as and when it wants to. Can I remove the unit and soak it in oil? Thanks for any help offered.
Idle control valve
Hi thanks for the advice. I have undone the two screws both side and removed or ring, but I am unable to pull the idle control valve out! How much force can I use before I damage it?
Many thanks!
Many thanks!
Re: Idle control valve
Many thanks!
Many thanks!
Originally Posted by Nash
My valve gets clogged with crap every few months, i took it out this morning cleaned it up and now its fine.
Woodford cant even get this part now as i asked last month. I luckily have a spare just incase my on finally dies.
Many thanks!
Many thanks!
Had to clean mine up again this morning worked for 10miles then shit again Looks like the spare is coming out if only it wasn't a 200mile drive to go get it lol.
You can not sure it all toghter but then your have to sit there with you foot on the t/peddel untill it idles
ICV
Managed to free it up. Tapped it with a hammer. Full of crap!!! Cleaned it up and fingers cross it has been behaving itself. Many thanks for the great advise!!!!
