saff scorpion exhaust
hi. i have a nearly brand new scorpion stainless exhaust system 3 inch bore from turbo to the back box then 4 inch tail pipe.
it has a middle box that i was thinking of cuting out but i am unsure as to wether it would cause running prolems do to loss of back pressure???
any ideas?
any ideas?
My m8 did it to his Scorpion on saph,was very loud
Scorpion system have got a small backbox,and a bigger middlebox,so they are loud if middle box removed.
My Mongoose has had the middle box removed,but the mongoose has a big back box and a small middle box,so not as loud as a scorpion
IMO Scorpion is too loud with middle box removed,all depends how loud you like your car though
I've got the middle box cut out of mine, with a 4 inch tail, sounds lush, I think it just amplifies the sweet song of a cossie and sure does sound good on idle or when launching hard
Do it
Do it
Just middle and backbox
So if i take out the middle mox, it makes the exhaust note louder, does this fail the MOT emissions test or anything? Also how do you reconnect the pipe? Just weld and clamp?
LOL,confusing your cos with a festa
Bought some stainless pipe for mine from Demon Tweeks,then had it stainless welded
Can see it on this pic,ignore the cats eye damage on the exhaust
I have a brand new blue flame one on mine ( mongoose really ) and i nearly tore the centre box of on a huge speed bump its all dented now and im gont take it out, i used to have a twin magnex and i had both box`s off that to, i was alot louder than my blue flame but when i get the centre box removed it should be the same, i like it cos my neibours are arse hole`s who dont like my car anyway and i just love starting it at 6.00 in the morning
my magnex system has
3inch pipe from manifold to..
2 boxes parrellel to each other then the two pipes that leave them join into one at the end of my exhaust
Back Box
does this make sence as i want to cut the middle boxes out.
ccheers luke
Back Box
ccheers luke
are they standard bars welded to your exhaust holding it up??
Had stainless bolts welded to the ends where they go through poly mounts,no chance of it popping off the mounts now
