Cam seals STILL leaking!!!!!
Just had my 2wd sapp repaired and got it home only to find camshaft oil seal leaking from same place as before ...
Is this a common problem?
Please help
Please help
thanks for the help pal but have found prob they must have forgot to retention the bolts after warming the engine as i just put half a turn on each bolt has not cured it so they will have to re do it. Ps lovely car!!!
Mine did that after I rebuilt it, hadn't used any sealant so had to re do it Has solved the problem though it has developed a new leak that I haven't managed to trace yet
There are 2 allen screws behind the cam wheels (one behind each) and they have a small O ring which fails. This might be a good place to look as it often gives the impression it is coming from somewhere else i.e cam seals. I believe the oil is under pressure as it is a main oil gallery. It was spraying on to the cam belt on mine and then going everywhere
07-10-2015 12:56 PM
