whats the difference between a 2wd and 4wd engine loom?
i have a loom that came with the rs200,can you tell the difference and does it matter which 1 it is?
i take it they will both mate up to an L8?
is there different connectors between the 2?
cheers
dave
cheers
dave
Drop Ryan off here a PM,hes very helpfull when it comes to looms
ECU plugs are the same,both will fit L8.
But if its a 2wd loom the two outer wires on the TPS plug will need swapping around to run on the PF09 TPS and L8
Depending on the age of loom if its a 4x4 one it should have a connection for a Lambda sensor and also a knock sensor which the 2wd ones don't have
few differences.
kev has mentioned a few.
Obvious difference is 2wd looms are one peice, 4x4 are 3 peice items.
Minor differences are:
WTS guage sensor in different place.
4x4 loom has an oil pressure wire aswell as lambda and knock sensor
2wd loom has a different place where is connects to the main car loom.
TPS wiring is different
big_Rad
15-09-2017 09:36 AM
rog
04-09-2015 12:10 PM
muz
16-08-2015 12:57 PM
