Saph water leaking into boot
Read somewhere here before think something about lifting the rubber seal up or something?
But basically water manages to drip at the end of the rear 1/4's into me boot as its only wet around there. Kinda doing me head as i need to get it sorted. Pretty sure its not the light as ive checked and replaced the seals.
So would anyone else know where else the water would be seeping into the boot from?
cheers
reiss
cheers
reiss
Was gonna say check your rear light unit seals but if you have changed them (don't do up too tight) it could be the boot rubber itself or water could seep in through where boot spoiler bolts onto the tail gate/boot lid,
best thing to do is get in the boot with a torch shut the lid and then have someone hose the car down with water, hopefully you will then detect where water is getting in
Luciano
Luciano
Thanks for the suggestions lads. Lying in the boot with a torch sounds funny lol but is a very good idea so if need be ill have to try it.
Hopefully bolting down the spoiler and sealing it at the same time. Will also check the catch just hope i can get it sorted
Anymore ideas please fire 'em in
Reiss
Reiss
If it is weeping through what could that be the rubber seal behind the light? I replaced the light with good seals?
