Oil Consumption
Oil Consumption
Hey People,
My cossie 4x4 uses +- 0,8 Litre Oil on +- 620 Miles
Is that normal??? If not, what could be wrong?
Would it be possible that my turbo is worn?? The car smokes a bit wen I let the accelerator loose (after I give a max. turbo-boost)
The spec's:
- 803 greens
- 3 bar map.
- Motorsport sparkplugs
- Motorsport powercables
- K&N 57i GR A
- T03 Garret (original) Peak boost 22 PSI con. 19 PSI
- Garret -31
- Mongoose 3"
- Collins Chip
- Forge Breatherkit
- Bailey Headertank & Swirlpot
- Gr. A Gasket
- ARP Stud & Nuts
- Nomad Racing Dumpvalve
Please give me some advice! Thnx
The spec's:
- 803 greens
- 3 bar map.
- K&N 57i GR A
- Garret -31
- Mongoose 3"
- Collins Chip
- Forge Breatherkit
- Gr. A Gasket
- ARP Stud & Nuts
Yea, my Sapph is a greedy oil monster too.
Similar specs to you Mr.Ford and uses a touch less than your does.
I also get the smoke when I put my foot down hard
My Sierra Cosworth 4x4 (with MSD 330kit) uses about 2,5 litre on 6,000 miles/10,000 km. Your car should use some oil and I believe Ford says up to 1 litre every 600 mile/1,000 km is okay.
However, there should not be any blue smoke from the car!!
IF a car does use a bit oil, is has to smoke!
Because, how else did it looses his oil???
I think it's rather much, but if all the cossie-drivers have got the same useage then it will be normal I think
Mr.Ford is bang on there! if it's going to burn even the slightest bit of oil it's going to smoke to some extent. surely if ford say 1 litre to every 600 miles is acceptable on a standard engine then surely you should allow a little more for a engine running higher boost pressures etc?
either way until it's getting to a point where you are having to stop every 15 miles to top up just keep driving it
Originally Posted by r5jame5
mine is a band new rebuilt engine running around 400 bhp built by harvey gibbs it uses a little more than mr fords .
in that case i would be taking it back because mine uses very little between oil changes.
mine uses 1 litre every 300 hundred miles and it chuffs blue on vacuum overrun (backoff), ive been told that this is either turbo or valves guides being completely knackered, as i had the turbo rebuilt 3 thou ago it seems likely that my problem is valves guides, will report more as soon as ive had em fixed.
Originally Posted by wimwerf
max oil the engine use per 1000km is 1 litre....anything more oil is not good...anyhting less is better...
But, I don't like the blue smoke (although it's not very much)
Originally Posted by The Gravedigger
Mine uses way more and it doesn't smoke noticeably??
Did you already have some one that watched from the outside of the car when you give full trottle?
If your cossie uses Oil ,then it has to smoke (a little at least)
Oil consumption on Turbo built cars is normall. they are often built with a looseer ring gap. Diesels do the same. It just depends on how it is built!
I rather mine use a little oil every 600km then to have stuff break because it is to tight when it gets warm.
deathrider666
28-09-2015 06:12 PM
