Broken rear wheel stud
Does any one know how to replace a single wheel stud on the rear of a saph cossie? I have managed to snap one! I know they are sold separately from Ford (49p). Many thanks.
If its anything like my fiesta setup, I replaced a front one, just removed the disc and caliper then drove it out from the front with a centre punch, then just put new one in and pulled in using the wheel and a nut then refitted disc and caliper only took about 20 minutes, hope this helps
You just need to bang it out, through the rear of the hub, with a hammer. If it's sheared off flush with the surface you will need a suitable prop to hit it with. Best advice is to replace all 4 of them, as the others may have been weakened if you lost the stud due to wheelnuts working loose.
Originally Posted by C0S_TURBO
All fixed. Just knocked the snapped one straight out and pulled the new one in with a spare nut.
Many thanks
Many thanks
bigluke200
14
02-09-2015 10:35 PM
Marc sierra
12
30-08-2015 10:38 AM
GTR_STU
28-08-2015 01:02 PM
