Stage 3 - Pinking
Stage 3 - Pinking
I tried to upgrade the car to run greens. I set the CO to 3%, fuel pressure was checked about month ago and was adjusted to 3.5 Bar.
The car was going like a clock with stage one set up at 15 PSI, but on greens the car was pinking when set to anything above 18PSI. The green injectors were brand new but I had another brand new set of greens to try. Same problem.!!!! Tried another 3 Bar MAP sensor and was still pinking. The chip I was using was a Ahmed Bayjoo and just to test that I got another Ahmed Bayjoo chip that had actually been live mapped for my car. My mate had acquired it off the guy I bought my car from. This chip was slightly better and the car ran smoother but it was still pinking after 18PSI.
I would go a run and then remove all spark plugs, Pistons one to three would be wet but No 4 would be dry. Another thing i noticed, if it was idling in the garage i could see and smell that it was running very rich. Slight black smoke from the exhaust. This was about a month ago and I decided to go back to stage 1 set up and the car is running great.
I am thinking about trying stage 3 set up again, does anyone have any ideas.
Im stating what should be the obvious but are you using super unleaded????
I would just take your car to a specialist or talk to one of the tuners on here for some pointers , no offence intended but it seems to me like you have tried a DIY stage 3 conversion and it hasnt worked out.
good luck
good luck
found what was wrong the earths going to the connection on the ecu had a bad contact and the fuel pump plugs were not giving a good connection and the bracket that holds the glove box was slack causing a metalic noise lol as for diy conversion lol i am not building a 600 brake monster .
JK12
33
26-04-2021 12:09 PM
Mc5506
05-10-2015 09:57 PM
