Help needed...mk1 frs brembos onto 2wd saff
Old 16-12-2010 | 10:49 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Default Help needed...mk1 frs brembos onto 2wd saff
Hi all,
anyone reading my resto thread will know that I have a set of frs brembos waiting to be fitted to my saff...
Problem is I need a new braided line to go from the caliper to the break line but I'm unsure which to buy....obviously these things are quite expensive so I dont want to buy the wrong ones!
There is no fitting in the calliper at present, just the hole where it used to be...
Thanks in advance!
Old 16-12-2010 | 11:09 AM
bad boy rs's Avatar
bad boy rs
Frs braids are fine mate that what I used on mine when u had these on my SAPH
Old 16-12-2010 | 05:32 PM
ShiftyOldScoob
Cheers for that mate,
This is probs a daft question but does the braided line come with the fitting that screws into the calliper itself
Old 17-12-2010 | 02:42 PM
bad boy rs's Avatar
bad boy rs
im not sure mate as mine came with it all, its a standard fitting though sure you can get them from ford
Old 17-12-2010 | 03:11 PM
Paynee's Avatar
Paynee
not usually i dont think, as said though just a standard item, probably get one from your local motor factors nevermind ford
Old 17-12-2010 | 05:29 PM
Any decent hydraulics place can make up exactly what you need cheap enough.
01-11-2015 07:53 PM
cossie330
27-09-2015 05:13 PM
DavidK
27-09-2015 03:55 PM
ajamesc
27-09-2015 03:25 PM
Russ Payne
25-09-2015 09:29 PM
