inlet cam ?
inlet cam ?
is it the kent cw7 that can be used without valve cutouts ?
ive found it on the website but can find a price, any ideas how much it costs?
want to get one as im putting a fresher engine together but depnds on price if i get one
cheers paul
cheers paul
Just to dispel any myth that EP have any magic abilities cam wise, if you have enough lift you will need cutouts as simple as that, you can alter the duration by increasing it if you really need lower lift to avoid cutouts, but will run filthy owing to having more over lap with inlet/exhaust.
A regrind is a LOT better imo than a new virgin cam, as it has already been heat cycled, I have used regrinds for over 25 years without a single fauilure even on pinto engines.
Most cams are copies of other peoples profiles, me gf's astra is going to run a pinto profile cam in her little 1.4 ohc for example
If you want a regrind i can supply you one for any spec.
If you want awesome low down torque and big power i have two very special profiles..
cheers danny
No myths mate just a totally different cam than whats on the market and not a copy of anyone elses although mad do a very similar cam with very good power etc...
cheers danny
cheers danny
Mark
As for having different profiles well of course its not one fits all but to be fair id only use 3 profiles between 400 hp and 700 hp now as there isnt any other profiles i need anymore..
cheers danny
Bit confused now, rang Kent to order the cam an he said the cw7 needs adjustable lifters which are an extra 350 quid ! He recommended the bd10 instead as it uses normal lifters and doesn't need cutouts, isn't that almost the same as a standard cam ???
01403263196 and speak to luke or call me direct on 07960144497..
cheers danny
Give us a buzz mate and il get one done for you,exactly the same as the ab07 that will work spot on for you,also you will want it timed spot on with a dti gauge to get the best from it..
cheers danny
cheers danny
07-10-2015 12:56 PM
