4x4 spah cossie power
i''ve just bought a 4x4 saph cosworth about a month ago and was wondering what sort of power to expect from the spec.
the spec is
RS500 intercooler
T34.63 turbo
Seimens 55lb injectors
wasted spark conversion
Group A air filter
It has anti lag and launch control setup from MSD if that makes a difference
The secs monitor says it peaks at 28psi, but i beleive this has been turned down from 36psi
cheers Lofty
the spec is
RS500 intercooler
T34.63 turbo
Group A air filter
cheers Lofty
Cake lover!
Secs monitor will only read up to 28psi due to it taking the reading off your 3bar map sensor [2 bar above base and 1 bar below]. Anything mapped past 28 psi with a 3 bar map sensor is partial guess work and down to experience mapping.
I would say looking at the spec depending on the boost 360-380bhp on a realistic set of rollers.
the spec is
RS500 intercooler
T34.63 turbo
Group A air filter
cheers Lofty
the spec is
RS500 intercooler
T34.63 turbo
Group A air filter
cheers Lofty
JK12
33
26-04-2021 12:09 PM
