Inlet differences
What inlet manifold differences are there from the 2wd/4wd sappfire and the escort large turbo/small turbo? The reason i ask is that i have read several times now that people with big hp conversions use a small turbo escort inlet manifold. So maybe there is a particular reason for that?
Most of the ones that are changed are not needed, the original 2wd one is capable of good power, depends how much you have, personally I would always try and keep the plenum volume as small as possible.
The 4x4 ones are far improved over the 2wd ones and unless your going for over and beyond the 400 hp mark is all you need after that id suggest a hart plenum as that far exceeds any of the oe ones in terms of flow and volume..
cheers danny
cheers danny
cheers danny
The hart plenums are £500 all in with the linkage and throttle bracket and are far better than any oe plenum..
A st escos plenum and t/b can set you back £300+ if you can find one..
cheers danny
cheers danny
On mad rods engine it made another 47 hp iirc over his 500 plenum and on the test engine it made 30 hp more at circa 500 hp and the torque was increased right across the rev range
cheers danny
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
