Mahle Pistons 2wd sierra cosworth
![](http://i52.tinypic.com/qys1up.jpg)
Had the machine shop who were going to bore out for these saying they had been machined and were incorrect .
To low a compression.
So i contacted my source and his reply was
iam afraid your machine shop hasnt got a clue about cosworth engines then,the piston were machined to Colins performance data,decked 1mm to avoid piston to valve contact and the sides bowled out to lower the comp,the piostoms are perfectly fine to use i have used loads to the exact same spec.
Are there any qualified thought as i don't no the supplier or the machine shop well.
I do have a sneaky suspision the machine shop is used to oval bored out pistons standard n have not come across any Mahle ones before,so have not met the spec.
What do you think?
Just looked a piccies of my pistons, and they are much deeper chambers in mine, going by that the piccie appears to show yours are higher, but impossible to say with out crown to pin measurements etc as the whole crown on yours could be lower for example.
I no longer have any of my old ones to measure for you though.
If when installed they come about 20-30 thou proud of the block as mine do yours will be lower than mine as my std chamber is much smaller diametre, as the outside edge is much wider.
Right i still have two conflicting stories.
What do i do .
I wonder if i could send one to this collins place to see if they are usuable.
I noticed the pistons in the pic are smotthed on the edges .
The lad at the machine shop mentioned edges cause crack points.
so i could just have the edges rounded.
Detonation was mentioned.
also the machined out part was to much.
I still do not no what to do.
The machine shop has a high reputation.
Still at loggerheads.
The pistons have also been said to be fine and the design/spec have been used on there cars.
o and am i the OP's
What do i do .
o and am i the OP's
They have been in my car to that spec for 10 years. Have a look on my resto thread to see how they still look today ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
https://passionford.com/forum/restor...bay-resto.html
Apparantly they are 7.2:1 on a 2wd car and 7.5:1 ish on a 4x4? Plus they've given enough clearance for me to run a BD14 inlet cam.
Is it normal for the pistons to stand 20 though above block ? The 200 block I'm going to use next had standard 4x4 pistons and they are 20 thou proud I was a little worried about valve clearance
Is there any more on this.
I don't think i will be using the pistons at this rate as i have not enough to persuade the engineer that all is ok and he is having the last word.
cheers danny
The last reply works for me and i tend to agree.
Just i like the guy so need him to agree before i put the engine together.
If he does not agree there is a problem .
He has 30 years experience.
Is it the fact he has a broad experience and has only come across standard cosworth pistons.
surely he has met collins spec pistons.mahle forged before.
If not how does the lads who are pushing 450bhp that uses him get bye.
maybe they should have a set n push 500bhp.lol
Yep mahle.
I think as they have are clean on the top they have been re machined since they came from Mahle.I am going to a rally shop to see if i can put one at the side of a new one.
I think there is one in Blackpool Road n Rally.
I want this sorting this weekend as the garage who is building it all will be wanting there space back lol.
I need a st220 engine building the block has let me down again.
Any good value for money engine builders in lancashire that would do a V6
Did you,i totally missed that.
What do i do meet up sat morn or what.
Cheers Lee
I am of work all day Friday as well
Cheers Lee
Like to thank Lee for good info at the mahle piston confrence.
I will have another go to pass muster at the engineers ,but some how i am thinking it might be just best to buy some more.
If i was to radius them n take the block down.
The machining cost will be alot more than another purchase.lol.
What a good lad ,totally focused on the Cossie,my mondy didn't get a mention.lol
Sourced new cp pistons ,forged with valve cutouts.
Very nice back on track.
Have all but a crank now.
Hopefully will have the car back together soon.
Then sort things out whilst she is running.
www.rallyanarchy.com
Just procured the full spec.
Its my first cossi so here goes.
CP forged pistons with a 4x4 head.
Cossi rods,crank n block.
Arp everything.
T3 turbo,going to T35.
Ecu with collins chip.
Larger intercooler.
Live mapping to do as advized by Lee.
Been a trek but have an excellent diff n gearbox.
Going to have diff ,gearbox n 3" exhaust fitted soon.
Waiting for the engine to come out of rebore.
Has any one used V6 pistons on the cossi to take up to 2.1.
I heard the essex ones work but i have 4 spare duratec 3.0 of a st220/jag.
would these work
Arp everything.
Larger intercooler.
would these work
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
155lee
14-08-2015 11:21 AM
adam151082
11-08-2015 04:50 PM
