turbo identification?
can someone help please by identifying my turbo? im currently running 803's rs 500intercooler and stage 3 chip what power will this turbo go to?
i want to go to greys or siemens 55lbs and l8 but dont want the turbo to hold me back!
It LOOKS like a T3/T4 Hybrid with a .50 A/R compressor
Not sure the A/R of the turbine side but its probably marked on there somewhere.
IF it is the turbo I THINK it is.. it should support 350 RWHP+ pretty easily.... and up to about 25psi before it really start heating the air up too badly....
I could be wrong, but what you've got there looks to be an
'ebay special t34 ish kinda thing'.
Wouldnt wana go big boost with it and expect it to last very long.
-up the boost and this is gona shit its guts pretty quick
I may be wrong, people may have other opinions on this for ya mate.
i thought the same fezman1 but its casted garrett on the exhaust side but cant find a a/r size cast on it anywhere. there is a bit of shaft play in it but no smoke.....yet just dont know whether to replace or repair
Is the shaft play side to side or in and out?
If its side to side and the wheels dont seem to be scraping when you turn it while pushing to the side and no evidence of contact, then I would say run it...
Also is your igntion timing set properly?
Cam Timing?
Is the wastegate actuator tight against the swingarm or is there slack, it should be jsut slightly snug so the puck doesnt leak...
Cam Timing?
JK12
33
26-04-2021 12:09 PM
