cossie idling too high, any ideas??
31-12-2010, 08:55 PM
DURHAM RSOC
as above noticed the saph is idling at 2k the last few days has just started doing it any ideas what it could be cheers?
31-12-2010, 08:59 PM
Try unpluging the iscv see if it drops ....or could be a water temp sensor fault and thats causing ya running problems....
31-12-2010, 09:01 PM
DURHAM RSOC
iscv is unpluged mate was when i bought it, but its just started doing that the last few days
31-12-2010, 09:09 PM
hi scottyrs had something similar to that disconnected the tps sprayed and cleaned the connection all was well.
31-12-2010, 09:11 PM
01-01-2011, 11:57 AM
C**t
01-01-2011, 12:00 PM
Was gonna say air leak,. Get some easy start, spray it around the inlet gaskets and pipe work etc. When the engine note changes, you have found your leak.
01-01-2011, 05:39 PM
As above can't do the speed without the air, maybe a sticky throttle cable/linkage ?
01-01-2011, 05:46 PM
is it a 2wd? if it is i wouldnt be surprised if the idle screw has fallen out completely
you may laugh but i have been there
01-01-2011, 06:24 PM
check all your vaccum pipes,inlet manifold gasket,idle screw. it does sound like an air leak.
Quote:
Originally Posted by
Gary Osborne
this has happend to me to
01-01-2011, 07:11 PM
As said will be an air leak, my money would be on the plenum gasket, be do check the said throttle is not getting stuck open a tad which would cause this.
If there was no idle screw it would do the opposite and not idle at all.
Martin
01-01-2011, 08:47 PM
DURHAM RSOC
didnt realise i had all these replies i havent got the car at the minute its getting work done at a garage butwhen i get it back ill check for any air leaks and let you know cheers
01-01-2011, 08:58 PM
iv had this
1. air leak
2. take the iscv out as iv had one fall to bits which lets air pass into the inlet
01-01-2011, 10:11 PM
im sorry martysmartie but your wrong . ive had it happen
the idle screw falls out and air is free to pass from atmosphere into the plenum bypassing the butterfly altogether.
02-01-2011, 10:45 AM
Gary Osborne
Yea mine done the same, lost it when calling at my mothers but found it again.
02-01-2011, 11:24 AM
Fair enough, that usually only happens though when the lock nut is not tightened down correctly.
Martin
muffster
13
03-09-2015 09:40 PM
Ben26
27-08-2015 08:56 PM
Adam-M
26-08-2015 05:53 PM
JoeyBoyden
20
22-08-2015 03:23 PM
turbobill
09-08-2015 05:21 PM
