Fuel feed to rail
Old 15-12-2010 | 01:23 PM
bad boy rs's Avatar
bad boy rs
Default Fuel feed to rail
How do you un-do this fitting ? tried loads of times and cant shift it
Old 15-12-2010 | 02:55 PM
dazzle740's Avatar
dazzle740
I could be wrong but I'm sure you need a special tool to remove the factory fuel pipe
Old 15-12-2010 | 03:40 PM
RS SHAUN's Avatar
RS SHAUN
Easy, I use a jubilee clip, cut the nut bit off, then slide the clip up to the connector, then pull!
Old 15-12-2010 | 04:07 PM
nuttynil's Avatar
nuttynil
RS nutta
good tip ...
Old 15-12-2010 | 04:15 PM
cozzy jeff's Avatar
cozzy jeff
did mine like this came apart really easy.instead of the jubilee clip i used a 15mm copper olive.
Old 15-12-2010 | 04:49 PM
bad boy rs's Avatar
bad boy rs
Ok I dont understand that though, can you explain abit more Shaun mate sorry
Old 15-12-2010 | 07:13 PM
cossie604's Avatar
cossie604
Just a sec, I did a write up on this for the rsoc, I'll see if I can find it......
Old 15-12-2010 | 07:17 PM
cossie604's Avatar
cossie604
http://bbs.rsownersclub.co.uk/showthread.php?t=264166
I just use a small screw driver tbh.
Old 15-12-2010 | 08:06 PM
RS SHAUN's Avatar
RS SHAUN
Just like cozzy Jeffs pic Paul, there's a circular spring in the connector, so you need something ring shaped like a jubilee clip to realese it!
Old 15-12-2010 | 08:16 PM
LHD220Turbo's Avatar
LHD220Turbo
this is what you need to undo them http://www.justoffbase.co.uk/Air-Con...=9&category=90
you can just slide a thin piece of metal up as shown above ^
Old 15-12-2010 | 08:40 PM
In practice the sprung ring fixing is quite loose, I found just a screwdriver ground a bit thinner was enough just dislodged the sprung bit to one side through the tiny gap and pulled, came off dead easy, I have the correct tools but mate had these at time.
timsrs
13-11-2018 12:48 PM
01-11-2015 07:53 PM
Brickhouse
14
03-10-2015 08:28 PM
20/20 vision
29-09-2015 12:27 PM
