your thoughts please
Old 09-12-2010 | 10:26 PM
cozzy jeff's Avatar
cozzy jeff
Default your thoughts please
the top left hand hole has no thread in it,do you think id have to tap it or do you think ill get away with the other bolts holding it in without leaking.
Old 09-12-2010 | 10:30 PM
timster's Avatar
timster
I'd thread it personally
Old 09-12-2010 | 10:33 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
id thread just to be on the safe side
Old 09-12-2010 | 10:36 PM
cozzy jeff's Avatar
cozzy jeff
any idea what size tap to use?i think its suppose to be a m8 bolt that should have been in there,if i tap it with say a m9 bolt wont i have open up the hole in the water pump also.
cozzy jeff's Avatar
cozzy jeff
scotty did your plugs turn up today?
Old 09-12-2010 | 10:41 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
no mate emailed matt lewis said they were sent monday and should of been here 1-2 days so there defo late im a bit p***sd off like
Old 10-12-2010 | 10:58 AM
As said defo needs tapping, you most likely will have to open the hole up a bit in the pump but lots of meat to do so, some one was seriously over tightening to strip a thread there!!
Old 10-12-2010 | 12:14 PM
martynhomer01's Avatar
martynhomer01
helicoil???
Old 10-12-2010 | 01:06 PM
cozzy jeff's Avatar
cozzy jeff
to be honest tabs the hole is smooth inside,my first thought was that maybe a dowel went in there,but i cant remember taken one out when i removed the pump.possibly someone in the past has had a go at drilling the threads out and not completed the job.
tabs what size tap would you use to re-thread the hole.
Old 10-12-2010 | 01:08 PM
cozzy jeff's Avatar
cozzy jeff
Originally Posted by martynhomer01
helicoil???
had no experience with helicoils but will look into it.
Old 15-12-2010 | 09:21 PM
cozzy jeff's Avatar
cozzy jeff
just to update,had another look at my water pump today as i was painting it,if you look at the picture you'll see that there is a hole in the block but no provision in the pump to put a bolt through,has anyone got there water pump off at the minute to have a check to see if this hole is supposed to be threaded or is there different pumps that actually use this hole.
Old 15-12-2010 | 11:03 PM
cossie604's Avatar
cossie604
lol I was just thinking that I didnt recall that hole being threaded/in-use as I looked at the first pics
Old 15-12-2010 | 11:56 PM
I'll try to remember to look at my pump tomorrow for you.
Old 16-12-2010 | 11:15 AM
derekd's Avatar
derekd
no need for a bolt there mate rebuilding mine and is the same mate
Old 16-12-2010 | 03:49 PM
cozzy jeff's Avatar
cozzy jeff
so whats it there for?if you look at the back of the pump water flows from the pump into that hole.
jameswrx
Modellers Corner.
17
09-10-2015 09:26 PM
gcfcos
59
06-10-2015 06:04 PM
Fezman1
02-10-2015 02:22 PM
Kiran1600E
11
02-10-2015 12:35 PM
gingeRS
17
02-10-2015 10:42 AM
