BD14 idle and emmisions
Will i get any problems with rough idle or high emmisions with a BD14 inlet cam? I currently run with a BD10 inlet cam and std. exhaust cam and the idle and emmisions are perfect. (The chip is a msd closed loop) I also have adjustable vernier pullyes on and have timed the cams as they should.
This is how it looks now on 2500 rpm:
Co% = 0,3%
HC = 60 ppm
O2 = 0,1%
Co2 = 14,9%
Lambda = 0.998
Could a BD14 cam uphold the same numbers if the chip gets recalibratet?
Co% = 0,3%
HC = 60 ppm
O2 = 0,1%
Co2 = 14,9%
Lambda = 0.998
TT T38 Power
You will need valve cutouts to use a BD14
Try a AB07 from Kent Cams
AB07 spec = 1500-6500 powerband, .349" lift and 256 duration
BD14 spec = 2000-7000 powerband .351" lift and 261 duration.
I have the AB07 cam and it drives great, drives like normal but made about 25-30bhp more peak power than a standard cam but at 7000rpm made about 45bhp more.
Steve
Steve
Steve
Steve
The AB07 is between BD12 and BD14, a lot closer to BD14 than 12.
