Ecu resistor wattage
Sierra 2wd ecu
Ok this i think could be comman.
The screw was turned up to high on the ecu.
Tickover i think.
My resistor burnt out.
it reads .33 ohms,wire wound resistor.
The problem is the wattage.
the number for the wattage was burnt out .
could any one have a circuit diagramme or now the fault n resistors wattage i am going on about.
If not i will try a 3watt
Tickover i think.
Turbocharging Technician
You have the right idea starting low, monitor it, if it gets hot then increase the wattage accordingly, unless of course someone can supply the correct information
Dr. Ickxs
15-09-2015 10:15 PM
DixieTheKid
14-09-2015 09:04 PM
