opinions on spec
Old 23-11-2010, 06:37 PM
cossie362
cossie362's Avatar
Default opinions on spec
hi guys
this will be the spec on my 4x4 sap
if all goes to plan
siemens 83s black
t4 with gt30 housing
standard cams
uprated fuel pump
air tec 500 intercooler
3bar map sensor
full re map to suit
what can i expect with this sort of spec?
Old 23-11-2010, 06:53 PM
derekd
derekd's Avatar
what gearbox you using??diff's with this spec mate
Old 23-11-2010, 06:55 PM
cossie362
cossie362's Avatar
standard box at the moment mate
looking for advice on diffs?
Old 23-11-2010, 07:21 PM
derekd
derekd's Avatar
would say u need a uprated gearbox and front diff with this spec on a 4x4
Old 23-11-2010, 07:22 PM
Paul_RS
Paul_RS's Avatar
I'd not use a T4, they are quite laggy. You need to be able to rev the car more than standard to make the most of them. Seems a GT3071 will give you 400+bhp and be alot nice on a road car.
As for diffs, front get a thickwall casing and an ATB. Rear ATB and then worry about 3rd gear exploding all over the road in your gearbox
Old 23-11-2010, 07:31 PM
cossie362
cossie362's Avatar
thanks for the replys guys
paul rs are you running a gt3071 mate?
over option on the turbo was a t34 with a .63 housing if i can get one?
the housing that is
Old 24-11-2010, 09:35 AM
I'd also not use a T4 due to lag and the hard hit it comes in with, the trans is a bit weak on 4wd, so a softer hit would be better, maybe a BB T34.63 ?
Old 24-11-2010, 09:47 AM
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
A front diff plate would be the cheapest option there and a 2wd rear end is cheaper than an atb 7 inch rear diff and then its just the box but if you ran a gt3071 and a spacer on the 4x4 inlet plenum you can get a realy smooth power at circa 2bar boost that wont kill everything,my road escos has 380 hp with 370 lb ft and is doing fine with over 20k on that set up with all std transmission,just make sure you uprate the engine mounts..
cheers danny
Old 24-11-2010, 05:07 PM
Paul_RS
Paul_RS's Avatar
the housing that is
I've some form of weird T34 on my car, nobody is quite too sure what it is lol. I plan on going for a GT3071 next year though as it'll do all i ever want. The thing with a t34 .63 is that you can't really get over 400bhp with them whereas a GT3071 will do 450+.
Mark Shed was able to get big power out of a sapphire with a GT30 on it with not much engine work - standard head, uprated cams and pistons IIRC. It was 480bhp again IIRC. Owner is on here but i can't remember his name
Old 24-11-2010, 05:42 PM
Staffi
Staffi's Avatar
hi guys
if all goes to plan
siemens 83s black
standard cams
uprated fuel pump
3bar map sensor
full re map to suit
What's the car going to be used for buddy??
If just road then i'd scrap the above Spec and go T34.48 for awesome punch and drivabilty AND reliability too.... and save yourself some pennies.
I have a TT T35.63 Live map, 72lb Siemens and it's a hoot of a road car, peaking @ 33 psi so it gives a great kick uo the ass too..
Old 24-11-2010, 05:48 PM
cossie362
cossie362's Avatar
hmmm decisions decisions, ive knocked the t4 on the head now so
might give the t34 i have a try and save for a gt3071
what is the goin rate at the moment for a chip and re map to suit guys?
Old 24-11-2010, 05:51 PM
cossie362
cossie362's Avatar
hi pete
just a road car mate to be honest
covering 2k a year
Old 24-11-2010, 05:55 PM
Staffi
Staffi's Avatar
hi pete
covering 2k a year
Well in that case pal i'd forget about the T4 idea....
A T34 car especially with a .48 housing and some 55lb Injectors live map will be awesome, trust me, i had that Spec 5yrs ago and it was fantastic...
Old 24-11-2010, 05:58 PM
Mark Shead
Mark Shead's Avatar
Just mapped a GT3071 today and made 2.1bar boost at 3400rpm in 5th.
Mark
Old 24-11-2010, 07:36 PM
Mark
What torque did it have at 3.4k???thats mental boost by then!!!!love the 3071!!was that with your inlet cam mark?
cheers danny
Old 24-11-2010, 07:39 PM
Mark Shead
Mark Shead's Avatar
cheers danny
On the dyno tomorrow, Yes its got one of my cams, the engine was done by FMS and we changed a few details on it and has a Spec R intercooler.
Mark
Old 24-11-2010, 07:46 PM
Mark
Nice!!will you post a graph?or atleast post to say how it gets on?love seeing all the info and data on these engines..
cheers danny
Old 24-11-2010, 07:48 PM
Mark Shead
Mark Shead's Avatar
cheers danny
The owners son may post it on here.
Mark
Old 24-11-2010, 08:09 PM
Mark
I think iv now worked out the car..lol..ok cool
cheers danny
Old 25-11-2010, 07:08 AM
rsmark86
rsmark86's Avatar
lol mine is my road car and its on autronic with gt35 and 1000cc injectors and im going to get a hart inlet and a remap soon aswel lol
its mapped at 2.2bar by mark @MAD and its a great set up full boost is kicked in at 3600rpm and starts making boost around 800rpm before its very lively for a big turbo car and is more punchy then some t34 cars ive been in
Old 25-11-2010, 07:29 AM
J1mbo
B1mbo
J1mbo's Avatar
hi guys
if all goes to plan
siemens 83s black
standard cams
uprated fuel pump
3bar map sensor
full re map to suit
the best thing for a standard engine imo is a t34.48 with blues, 3 bar, cooler etc, and it will make for the best road car, 370/80 bhp and similar torque, not much lag at all and will fly, for a weekend toy its plenty of power and as danny has said the transmission will just about hold in one bit, we do so many of these conversions and every customer has absolutely loved them
Old 25-11-2010, 07:59 AM
Staffi
Staffi's Avatar
Mark,
Sorry mate, but imo a T34.48 is a great road car, i'm not knocking your spec but a GT35 can't be called the perfect road car...i think a GT3071 that Mark does would suit you even better than your 35 setup too mate..
I'm just thinking about the original posters transmission too Mark imagine a standard 4x4 on a GT35... a gearbox a week,....
Thank you Jimbo, sense at last...
Old 25-11-2010, 12:48 PM
rsmark86
rsmark86's Avatar
Mark,
lol im not saying its a bad conversion as ive been in a nms live mapped car with your set up and its a great conversion...
but trust me there aint much difference between the t34 to the gt30 at all ...
my mates escos with t34.63 i feel needs revving more than my car due to being low comp plus mine is mapped realy well on autronic...
and this is why most tuning companys are pushing decent gt series turbos as they are a nicer set up ... can run more power with no more lag
Old 25-11-2010, 01:51 PM
Staffi
Staffi's Avatar
Mark,
I hear and get your point, i only keep hearing great reports on the 3071, infact
Old 25-11-2010, 02:09 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Mark,
One day you will make up your mind
Steve
Old 25-11-2010, 02:17 PM
lee2cossies
lee2cossies's Avatar
Whats a gt3076 like in comparison to a gt3071? Roughly what rpm would a gt3076 start to boost at? sorry to hi jack the thread!
Old 25-11-2010, 02:47 PM
Staffi
Staffi's Avatar
Old 25-11-2010, 02:52 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
It's only money Steve...
Cossie ownership isn't meant to run smoothly & cheaply anyway, you know that this year...
You only told me yourself the other day that there is sod all wrong with your T34
Steve
Old 25-11-2010, 03:06 PM
Staffi
Staffi's Avatar
Steve
Lol,
It's a T35, please get it right..
T38 & Cam is tempting right now Steve....
Old 25-11-2010, 03:08 PM
rsmark86
rsmark86's Avatar
well my gt35 starts making boost alittle after 2500rpm and makes full boost around 3500rpm....
but its specced to my engine with standard compression...
and pete i would never had spent the money buying the gt35 but id never been in a car with one .... but now i will never have anything else and a mate of mine that built a same spec car with a t4 says mines on boost nearly 1k earlier ....
Old 25-11-2010, 03:11 PM
Staffi
Staffi's Avatar
Mark,
What's your plans with it now then bud??
A remap back @ Sheady's place ??
What power's it making now Mark?? surley over 500??
Old 25-11-2010, 03:13 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Mark,
Not with a hole in his boost pipe
Steve
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Lol,
Please refer to the thread on the RSOC
Steve
Old 25-11-2010, 03:19 PM
rsmark86
rsmark86's Avatar
i will find out this week as the engine mounts are knackered at the mo but im ordering a set of mounts and new boost pipes with proper claps ect...
then will put back on a dyno next week but its ment to be 525bhp as it stands when it runs the 2.2bar but we will see....
but even with the boost pipe leaking and only holding 1.5bar it rapes my mates mk2 frs with js400 kit fitted so im happy lol....
but plans are
remap / service/ hart inlet
cts big tooth box with uprated folks and hydrulic clutch from reyland
have the dent fixed with full respay
then some big brakes and comps
Old 25-11-2010, 03:20 PM
rsmark86
rsmark86's Avatar
oh and with the car loosing all its boost and only hitting 1.6bar and holding 1.5 still made 414bhp and 416lbs@3900rpm
but is mapped to 2.2bar so should see 500bhp
Old 25-11-2010, 03:42 PM
Staffi
Staffi's Avatar
Hope all goes well then Mark....
Old 25-11-2010, 03:55 PM
sierrsteve1980
sierrsteve1980's Avatar
Exactly what i am going for oh and you guys are doing it lol, still need an ecu though l6 if you have one.
Old 25-11-2010, 04:24 PM
J1mbo
B1mbo
J1mbo's Avatar
Lol you'll love it, ahh I ment to get back to you about ecu didn't I ! Was it level 6 you wanted?you had pectel board already ? Can't remember now.
Old 25-11-2010, 04:29 PM
Staffi
Staffi's Avatar
Lol you'll love it, ahh I ment to get back to you about ecu didn't I ! Was it lever 6 yup wanted and you had pectel board already ? Can't remember now
Jimbo,
You been on the drink again?? some funny spelling there bud...
Old 25-11-2010, 04:31 PM
J1mbo
B1mbo
J1mbo's Avatar
its this poxy iPad it corrects things and pisses me off, best change that lol!
Quick Reply: opinions on spec
