cossie will not fookin start...
Old 02-12-2010, 06:17 PM
dazcossie
sapphire cosworth 4wd
dazcossie's Avatar
Exclamation cossie will not fookin start...
,if anyone knows how to sort this cos me and carlos fandanglos are stumped cars had a new cambelt and tappets fitted,no problems..the lads fired her up and ran it for 10 mins to see if all was ok,now it wont startive tried everything but im not getting a spark..cps is in the correct position and tdc markings are all spot on and gapped correctly.i have power to the ignition amp and coil but when you turn the key you get the first spark then nothing when you crank the engine i really dont know what to do other that a litre of v-power and a box of fookin matches...HELP
ive changed ignition amp,dizzy and rotor,crank sensor and every other sensor you can think of..the pump primes but im just not getting a spark..
__________________
Old 02-12-2010, 06:22 PM
martynhomer01
martynhomer01's Avatar
the factory alarm cuts spark only, that would be top of my list to check, its at the drivers side dash-kick panel area,there is an imobilisation circuit that runs across the bulkhead,to the engine loom plug behind the battery...
Old 02-12-2010, 06:32 PM
timster
timster's Avatar
Originally Posted by martynhomer01
iirc the factory alarm cuts spark only....that would be top of my list to check.....drivers side dash-kick panel area,there is an imobilisation circuit that runs across the bulkhead,to the engine loom plug behind the battery...i
Good Call
Old 02-12-2010, 06:39 PM
martynhomer01
Old 02-12-2010, 10:17 PM
dazcossie
dazcossie's Avatar
nice 1 buddy i'll have a look at that tomorrow...its a factory alarm that contols the opening and closing of the doors plus a vecta immobiliser..which is getting replaced tomorrow,thanks for your help
Old 03-12-2010, 09:06 AM
martysmartie
martysmartie's Avatar
Check that all four lugs are intact on the crank pulley, especially as you have just changed the cam belt, also at TDC is rotor arm facing 2 o clock?
Martin
Old 03-12-2010, 09:09 AM
dazcossie
dazcossie's Avatar
Martin
all teeth are intact mate,and the rotor in the dizzy is spot on at tdc!!! ive been through everything mate,im gona go down and dissable the immobiliser and alarm to see if it fires up
Old 03-12-2010, 09:25 AM
slimboyfat
steerfromtherear
slimboyfat's Avatar
As been sugested before
FOOOOOKING NAIL
Old 03-12-2010, 11:18 AM
Sonic Boom
Sonic Boom's Avatar
__________________
That's exactly what happen to mine mate and it was the bottom pulley, even thought it looked fine.
Might be worth changing it even if the lugs look ok.
Rich
Old 03-12-2010, 04:00 PM
dazcossie
dazcossie's Avatar
FOOOOOKING NAIL
cheers slim mi old chunky trucker
Old 03-12-2010, 04:22 PM
Paul_RS
Paul_RS's Avatar
Check the CPS connector on the loom side.
Old 03-12-2010, 05:03 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
your welcome mi old island knicker snifferYou know me matey always full of usefull and helpfull advice
Old 03-12-2010, 06:22 PM
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
Would remove/rewire the 3 multiplugs above the camcover Dazzle ......
Going to be a wiring fault some where silly
Old 07-12-2010, 09:00 PM
dazcossie
dazcossie's Avatar
ok chaps a quick update,ive stripped out the alarm and immobiliser and it still wont fookin start...any ideas?? cheers for the call earlier carlos
Old 07-12-2010, 09:04 PM
martysmartie
Just re read your post it seems you have suspected and changed everything bar the coil itself, do you even know the coil is working?
Also does the fuel pump prime?
Martin
Old 07-12-2010, 09:05 PM
dazcossie
dazcossie's Avatar
Also does the fuel pump prime.
Martin
hi martin yeah ive got a group a coil on mate its getting power to it.
Old 07-12-2010, 09:09 PM
martysmartie
You say power to it (This will be 12V+), but is it giving a healthy spark out of the king lead? Does the fuel pump prime?
Martin
Old 07-12-2010, 09:16 PM
dazcossie
dazcossie's Avatar
Martin
yes mate power to it,but im getting no spark..pumps priming but i dont think its squirting any fuel..took the plugs out after turning it over for a while and they were bone dry..
daz
Old 07-12-2010, 09:23 PM
martysmartie
Now it's starting to make sense, do you have another coil you could try?
If the pump primes I would assume the fuel delivery to be ok, unless the injectors are not opening.
Martin
Old 07-12-2010, 09:27 PM
dazcossie
dazcossie's Avatar
Martin
yes martin i put the standard one back on to try it,but i dont think the injectors are spraying mate and no spark...the only spark i get is when i turn the key to pos 2 but not crank the engine....it looks like cps is not picking up so i put a voltemeter on that and its picking up fine so looks like its on the loom back on the bulkhead!!! or the ecu is fooked mate
dont really know what else to do
Old 07-12-2010, 09:31 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
Fook me ya inbreedCheck that you have power coming out the coil via the king lead During cranking over
Old 07-12-2010, 09:33 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
It should pulse and it might have power surge when you turn the ignition onHad all this with he shogun if you remember
dazcossie
dazcossie's Avatar
get back in ya truck mi old peach cobbler...i know what he fookin ment tried that
martysmartie
Oh fair enough, the fuel pump primes so should think CPS is ok, I know you say it fired up ok after the belt change, but have you checked all the timing is ok (Given it shouldn't have changed)
Martin
Old 07-12-2010, 09:36 PM
dazcossie
dazcossie's Avatar
Martin
yes mate all the timing marks are spot on..pump priming wont make the injectors spray tho mate thats down to the cps surely
Old 07-12-2010, 09:38 PM
dazcossie
dazcossie's Avatar
yeah mate it pulses spot on when cranking over im fookin confuzzled now...might just burn it
Old 07-12-2010, 09:39 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
Fuck me This is almost as boring as damos power thread
Is there any body with an ecu you can use to check
Old 07-12-2010, 09:44 PM
martysmartie
It's info is used to generate a spark, as for the injectors I think they use various info to determine there respective pulse widths, one being the MAP I should imagine. It is the phase sensor that is used for sequential fuel injection, hence why when this gives incorrect info over fueling results.
Is the rotor arm in the correct position in relation to timing?
Martin
dazcossie
dazcossie's Avatar
cheeky fooker its no where near as boring as thatyeah mate ive got a pal with an l8 ecu so i'll borrow that off him tomorrow and have a look.....oh yeah ive added you on facetube or whatever its called.
Old 07-12-2010, 09:46 PM
dazcossie
dazcossie's Avatar
Martin
yes mate rotor arms spot on..im gona check the ecu tomorrow,im running out of options buddy
daz
Old 07-12-2010, 09:48 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
I did wonder who the stalker freak that sent me the request was
Old 07-12-2010, 09:49 PM
dazcossie
dazcossie's Avatar
it was me
martysmartie
Ok, keep us updated.
Martin
Old 07-12-2010, 09:50 PM
dazcossie
dazcossie's Avatar
Martin
will do martin thanks buddy
Old 07-12-2010, 09:55 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
No problem you welcomeI dont very often give out any advice just abuse
Old 07-12-2010, 10:01 PM
dazcossie
dazcossie's Avatar
and a BIG thanks to you aswell me old truck driving choir boy but your right you usually give crappy advice
Old 07-12-2010, 10:02 PM
slimboyfat
steerfromtherear
slimboyfat's Avatar
But its the best crappy advice around:shocked :
Old 07-12-2010, 10:04 PM
dazcossie
dazcossie's Avatar
as crappy advice goes mate i rekon you could be world champion
Old 07-12-2010, 10:10 PM
boost mad
boost mad's Avatar
if the ecu doesnt sort it it maybe worth sending the Loom to someone to be checked.
I no someone, pm if you want thier info
Old 08-12-2010, 06:09 PM
dazcossie
dazcossie's Avatar
thanks mate,i think ive sussed what it is at long last
Quick Reply: cossie will not fookin start...
