ive got a new BD16 inlet cam sitting in my room. Tempted to get the ports worked on and fit the cam to my saph along with a standard exhuast cam. Would it be ok ? how would it drive. Poweband etc
What inlet plenum do you have and what management etc??
We done a black 3 door on gt 35 with the same bd16 inlet and std ex on a swedish inlet plenum iirc and that done 549 hp and just shy of 500 lbft ,torque from 4k to 6.5k and a nice power band up to around 7k
The cam timing will need to be spot on to achieve this and obviously mapped well..
I thought you had to have the seats machined down if using isky double springs, but im using Newman doubles which dont require mods
With the newman springs it will be fine on the bd16 as iv said and you wont need a ex cam to make nice power and torque
Originally Posted by James90RS
I believe it is in the elbow?
Compared to say a hart inlet or similar then yes the elbow is restrictive but its mainly down to voloume hence why people space them and stuff..
As for them doing over 500 hp then i suppose with a spacer and shit loads of boost then its defiantly possible..
BD16 inlet and Std Exhaust is a good setup. Others will say different but I have been using it for ten years to great effect.
Alot of people have told me you advise a bd 16 inlet and bd14 ex on most occasions??
Infact untill just recently iv not heard anyone say they have used a std ex with a bd16 inlet.
Out of interest how would you set the cam timing on this set up??
A 16 on inlet and standard exhaust is nice, should see around 500 with a nicely ported head, 14 on the exhaust will move the power up the rev band and see a touch more power wise, the STD exhaust cam IMO gets restrictive around the 500 mark
Fuck me you agree with everything iv said apart from the t2 not being as good as the link and the ex cam running out of puff at 500 hp as iv personally seen them do 600 hp now but agree they bring the peak power down the rev range witch imo is spot on for a road car..
cheers danny
So apart from the t2 and the std exhaust cam, what exactly did I agree with
One thing, the rev range bit, You reminded me need to bump one of your other threads
Couldnt be bothered mate as in my 63 page book it says red square beam is tarmac and green beam is gravel!!!but you will still argue either way and tbf i know what iv got so dont really care..
Originally Posted by Mark Shead
The BD14 is worth it for 1% of the time and the stock cam is better for 99% of the time.
FFS!!thankyou...lol
cheers danny
I do love a reaction there's a tenner on that you know
Really? It just shows you that a little knowledge is dangerous. I wouldnt personally use a BD14 exhaust cam EVER If I had my way.
Timing depends on too many factors to answer a question like that!
I could name a few right now but wont,but the bd 16,15,14 combo is what they say youve said is needed with thier spec to sort surge etc??
Only going by what some have said so could be rubbish hence not mentioning names..
We are talking the said engine spec with a bd 16 inlet cam and std ex so theres not that many factors mate...in that case where would you start your cam timing from 112/112 110/110,its not a trick question just curious to your opinion??
Maybe it was other tuners who asked me? LOL
Anyway, sod all wrong with a BD16/BD15 combo, it works well on the right engine.
Danny, the peak lift point you are asking me for affects the engines peak power point and as such will need to be dialled to suit the max flow of the head etc which is not mentioned in this topic. If the compressor surges due to flow invariance you will simply need to bring the peak lift point down to nearer the surge point and then rely on pure pressure to make BHP as your compromise, but speccing the engine right in the first place is a better plan.
Im pretty fine on info mate about cams as iv done a few in my time but thanks...lol
Was just asking you what your starting point would be on the ops engine to see what you would say but youve answered how i thought you would!!lol
When i spoke to Stu regarding cam choices this combo was what was suggested to me.
This combo works well and much better than say a 16 and a 14 for a road car and low down drivability but in comparison to my new inlet cam there was 35lb ft and 52 hp difference on the same engine..
