converting my 4wd saph to 2wd help
hi all! right im fed up of blowing front driveshafts etc! im converting her to 2wd. i have already removed the front driveshafts and refitted the cv joint cups to hold the bearings etc in the hubs. this will save me money as wont have to buy 2wd hubs/struts etc. i am gonna remove the front diff and sump and obviously the gearbox and props. i would like some advice iff poss on what stuff i need? list of things i know of;
2wd sump and modify my oil pick up
t5 gearbox and cradle/mount
2wd prop
2wd speedo and clutch cables
please could anyone let me know if im mising something? im doing this on a bit of a budget. i will add pics as i go. cheeRS!!
2wd prop
What power are you running????if anything over the 300 ish hp mark then you will need the 2wd rear end and 7.5 inch diff..
The starter motor the sandwich plate between bellhousing and block i think that covers it..
cheers danny
cheers danny
cheers guys. i am running stage 1 at the moment but will be looking at stage 3 at some time next year. i have broken 2 o/s engine mounts so far and done 5 o/s driveshafts lol! i have just bought a set of collins engine mounts so will be fitting them too. i have also fitted a set of konis which has lowered the car
to be honest i really cant be bothered with the coversion but its the only option i can think of. though if i bought uprated driveshafts, those mixed with the collins mounts should do the job?
Cossiemodo
hi all! right im fed up of blowing front driveshafts etc! "Why should be your question"
hiya buddy i have a saff 4x4 with vibra tecnics mounts and also use xr4x4
front shafts never in 4 years have had a problem with them breaking even
with 390 bhp the car is on koni adjustables and is as low on the front as
ive seen on 4x4 saffs
here is a quick pic
here is a quick pic
![](http://i36.photobucket.com/albums/e12/bigad4x4/IM001082.jpg)
cool nice one mate cheers! yeah mine is exactly that low as yours. i got collins mounts i just bought so gonna fit them and xr4x4 driveshafts. cheers mate!
I had the same problem my car was to low on avo.s so ive put some xr4x4 shafts in u dont need no cerclips as these are longer mine were done abt 3 years ago no probs.Deffo cheap option and originale rather then conv.
just had a look at the gearbox mount and thats fallen apart too! another Ł56 on another collins mount! thanks for all the replies guys, ill let you know how it gets on on the rd
Russ Payne
25-09-2015 08:29 PM
