Carpets
Old 24-11-2010 | 03:33 PM
cossie891's Avatar
cossie891
Default Carpets
whats the differance with saph and 3 door carpets and the deadening?
Can saph stuff fit in the 3 door?
Cos I cant find a carpet and deadening close enough
Old 24-11-2010 | 04:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
can't see why not, it's only got longer doors so if you can fit the carpet around the b pillers then it should be ok
the sound deadening should be a doodle as well in that case
Old 24-11-2010 | 04:21 PM
cossie891's Avatar
cossie891
Cool up the scrap yard 2moro for the deadening then
Old 24-11-2010 | 04:29 PM
dojj's Avatar
dojj
they still did 3 door sierra's on the continent right up until 92 spec so that could be a bet
saying that though most have suddenly dissapeared over the past few months, i was going to get one when the prices were ultra cheap and then they just dried up, some were going for as little Ł300
Old 24-11-2010 | 04:34 PM
cossie891's Avatar
cossie891
I know some 1 on here has a mint carpet and deadening I just cant to them for it
Old 24-11-2010 | 05:09 PM
Gav Diamond's Avatar
Gav Diamond
I have put deadening out of a base model hatchback (5dr) in my 3dr as i wanted to use the heater pipes that go into the back of the car.
However the sound deadening sits off the tunnel as the tunnel must be wider higher up on later models than earlier ones. (if that makes sense)
Old 24-11-2010 | 05:18 PM
cossie891's Avatar
cossie891
OK mate cheeRS for that
So it will defo work then
steve.rst
15-03-2016 08:01 AM
mk1turboestate
02-12-2015 08:31 PM
07-10-2015 12:56 PM
S3an
26-09-2015 11:39 PM
S3an
13
13-09-2015 10:01 AM
Quick Reply: Carpets
