cosworth 2wd wiring loom problem
hello everybody,i would like to ask you about my original 2wd cosworth wiring loom,so does anyone know about these wires with red mark what run? any help really appreciated!!
image hosting service
thanks a lot
Themistoklis
thanks a lot
Themistoklis
aka Turbosailorboy
2WD wiring is:
green - from coil negative to rev counter
red - from permanent +12V to both relays (pin 30)
black - from switched +12V to both relays (pin 86)
black/red - from fuel pump relay (pin 87) to fuel pump
brown/white - from temp sender to temp gauge
Tried to find picture of standard Ford connector but haven't got one sorry.
Oil pressure is only on 4x4 engine loom
2WD wiring is:
2WD wiring is:
Martin
big_Rad
15-09-2017 09:36 AM
