remap due to head skim
hi can anyone let me know if i will a need a remap after skimming 0.3mm off the head as it will alter the compression ratio slightly im not sure how critical it is to the mapping? as you can guess its been skimmed a few times before lol
Good to check both ignition and valve timing as skimming will retard your cam timing slightly and the ignition may need to be retarded as the compression rises if its currently set on the edge. Both of these will be very marginal but definately extend your engine life and performance if set correctly..
saff is working!!!...atm
if it's a off the shelf chip NO.....but if it's live mapped then i'd deffo get it checked out......unless u drive like a girl then it wont matter..............(or use a different size head gasket)
Si B
12-09-2015 06:49 AM
