oil leak 4x4
Old 12-12-2010 | 08:45 AM
sundera86's Avatar
sundera86
Default oil leak 4x4
my cossy drop oil into inlet manifold only between first and second cilynder and after that oil drop onto distributor cap. I cant understand from where enfine oil come from ? Its not looking like a problem cam cover gaskett ! Any suggestions ? Is it possible the oil come from cam seals an half moon seals and goin onto inlet manifold and after that onto distributor cap(on distributor is the biigest amount of oil but it start from top side on the inlet)There is oil also on fuel injector only at first cilynder
Old 12-12-2010 | 10:01 AM
BIG WULL's Avatar
BIG WULL
Fae the Dale
hate to be negative but join the club. these engines seem to leak oil from every available seal. seems once you fix one leak another starts. my advice would be change all gasges about that area because if it wasn't leaking already it soon would be. but yes those rediculas half moon cam seals are always a favourite
Old 12-12-2010 | 01:16 PM
Moonstone Mo's Avatar
Moonstone Mo
Mine sprung a leak on the tb side and made a mess of that complete area,oil under injectors,over dizzy cap etc..turned out to be the oil pressure switch.
Old 12-12-2010 | 03:42 PM
sundera86's Avatar
sundera86
no it is not oil pressure switch, i ve already check this
Old 12-12-2010 | 07:39 PM
dazcossie's Avatar
dazcossie
sapphire cosworth 4wd
have a look at the oil cooler mate ive just replaced all the seals in that,you can get them fro woodford garage motorsport...had to clean all the engine first then run it to see where it was leaking form..worth a look but its a git to get to..
Old 12-12-2010 | 08:34 PM
Mine too, pissed lots of oil all over the place, as roosie will tell you, tried giving me a bill for cleaning his work drive!!
Old 12-12-2010 | 09:42 PM
Moonstone Mo
..i was shocked at the amount of oil it was loosing,my drive was ruind too!
Old 13-12-2010 | 05:21 AM
My oil switch was leaking at one point too. The oil was just dripping onto my drive. It was a constant drip though. At first i thought my sump gasket had gone.
BRAMMER
15
14-09-2015 09:52 PM
tib2220
14-09-2015 01:33 PM
truffleshuffle
10-09-2015 10:35 PM
Escortdriver1
06-09-2015 11:12 AM
Adam Graham
06-09-2015 07:04 AM
