im going to be fitting some compomotive mo's to my cossie in the new year they are the flat face 5 spokes ive been told i need to fit different wheel nuts and studs possibley group a ones
anyone know where to buy these from and how much they cost?
cheers
cheers
yours looks really well on them as well mate you got any more pics?
also what size tyres are you using and did you use spacers at all?
I've got a 10mm spacer on the rear to bring the it out to ET23 the fronts are standard on ET33
Rear tyres: 245/35/17
Front tyres: 215/40/17
Here's a photo:
that looks really well mate. 245's on the rear!! did you have to trim the arches at all? i was reccomended to run 225's on mine, i ideally dont want to trim the arches at all as my plastic arches are completley uncut and i would prefer to keep it that way if poss!
I got away with standard studs/nuts on my SApph with MOs and group a inserts? They are the curved spoke MOs though.
ive seen too many videos of standard studs and nuts shearing off on cossies with group a wheels mate so dont want to risk it! plus when putting the nuts on i found you only get about 5 full turns of the nut with standard studs and group a inserts which is no where near enough to be safe
Yes mate much trimage required of both the plastic and metal arches.
Rich
I can't remember how many turns i got on mine, but whatever it is Martin Hadland said it was fine. I have longer studs here, but i've never gotten round to fitting them lol.
