Help with breather port locations
Old 16-11-2010 | 10:25 PM
nuttynil's Avatar
nuttynil
RS nutta
Default Help with breather port locations
Hi had this breather laying about the garage can anyone tell me how and where the pipes should go .Thanks Neil
Old 16-11-2010 | 10:34 PM
Thanasis's Avatar
Thanasis
the up pipes-one to the cam cover and the other one to the geniune breather from block
the down pipes the small to return to the oil sump and the bigger free to atmosphere
Old 16-11-2010 | 10:43 PM
cossiedad's Avatar
cossiedad
I have one exactly the same on my 2wd Sapphire. Cannot remember them all, as my car has been in pieces during a rebuild for 5 years now! All going back together at the moment, so I'm referring to pics I took when stripping it.
One of the top pipes is for a breather tube that you need to have fitted to the top of your cam cover (at the back on the battery side).
The other top pipe goes down to the block next to the dizzy.
The big one at the bottom goes to the sump area.
I think! lol I am going on some bad pics from 4-5 years ago and I'm not with the car to look at it right now. I would appreciate if I have this wrong that someone can correct me as I am refitting my engine bay over the next week so will save me making a mistake.
cheeRS
Old 17-11-2010 | 09:42 AM
Fezman1's Avatar
Fezman1
The large one at the bottom - vents to atmosphere
The small one at the bottom - return oil to sump, blow oil level
The top two - one connects to the oiriginal breather
- the other one is controversial lots of folk put into the
cam cover???
I personally connect to the breather port at the otherside of the block
Old 17-11-2010 | 10:33 PM
nuttynil's Avatar
nuttynil
RS nutta
Thanks guys so undern the inlet do i remove the kidney box and put a pipe in it to connect to..
Old 17-11-2010 | 10:58 PM
fatmike's Avatar
fatmike
you can get adapters on ebay mate, they are dead cheap, just a machined piece of metal that fits into where the kidney box went. Then you just slot your pipe straight on.
http://cgi.ebay.co.uk/RS-Cosworth-Pi...4#ht_500wt_922
Old 17-11-2010 | 11:09 PM
nuttynil's Avatar
nuttynil
RS nutta
thanks
Old 18-11-2010 | 05:21 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Mine's on top of the kidney box
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
AJC
01-10-2015 06:47 PM
Steve Escos
01-10-2015 06:57 AM
caprixpack
25-09-2015 07:53 PM
Quick Reply: Help with breather port locations
