4WD cooling for 2WD
4WD cooling for 2WD
I am going to fit a 4x4 water pump and thermostat housing to an otherwise unchanged 3dr cooling system.
Which hoses do I have to go for ? I know about top and bottom hose have to be 4WD, but what about the hose running from thermostat housing to turbo and the one connected to the pipe below the cooler ?
I guess 4WD as well, but there are two versions (pre/post "facelift" - never heard about sapphire having been facelifted); I`m confused a little.
Maybe someone can clearify
Thanks
Stocki
Thanks
Stocki
You'd need pre facelift. the difference is the metal pipe that bolts to the bottom of the radiator. The pre facelift is the same as a 2WD sapphire, the facelift has a different shaped metal pipe, so the silicone hose that joins to it it different.
Thanks for the replies.
I have a brand new 4x4 pump and a shot peened thermohousing on the shelf waiting to go into my 205 block. Therfore I`m happy tabetha`s hasty assumption was wrong.
Stocki
BTW the head is genuine 3dr but has three threadholes for the thermostat housing - one being unused with the original one
Stocki
My "hasty" assumption was based on what I was told by a pf trader about 6 years ago who certainly should have known the correct situation, had I known this I would have fitted a 4wd pump to my own engine for the extra pumping capacity for a little extra peace of mind.
no offence, tabetha. I just would have been annoyed if the parts I bought for good money would have been useless for the 205.
I will give a report when installing the pump.
Stocki
Stocki
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
dojj
28
11-09-2015 10:00 PM
