clutch quadrant help plz
Old 03-01-2011 | 11:03 AM
5tox's Avatar
5tox
Question clutch quadrant help plz
lost my clutch the other day and it appears to need a new clutch (ratchet) quadrant.... the bit under the clutch pedal
ive got a 1988 sierra cosworth, at the motor shop he said is the part white black or yellow (different colours meaning different sizes)
gone up there today and hes ordered me a black one
on the bag it says 'clutch adjuster repair kit ford granada sierra 50mm'
does anyone know if this is right, i really dont want to take it to bits and find its the wrong part
cheers steve
Old 03-01-2011 | 02:40 PM
martysmartie's Avatar
martysmartie
It sounds ok but not sure by any means, should think the Sierra/Granada were the same, I presume it's the same colour?
Martin
Old 03-01-2011 | 02:44 PM
seanny 94 si's Avatar
seanny 94 si
Have you had a look at the old one and see what colour it is or isn't there enough room.
Old 03-01-2011 | 03:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there are 4 colours, black, red, yellow and white
my money would be on you having the red or yellow one
don't fit the wrong colour or you will quickly end up frying the clutch, snapping the cable or worse still, bending the pedal box
remove the entire pedal box, it's only a few bolts and that way you can dismantle it on the bench and it's much much easier to do
when you reassemble, make sure you thread the cable through the bulkhead and onto the end of the clutch pedal before you hook it onto the box end
Old 03-01-2011 | 03:54 PM
I'd fit the cable the other way around, that way you can simply lift the pedal, then push the quadrant forwards, fit the cable and release, I have a white one in the garage if any good, personally I'd just lock it and make it adjustable for under £5, never have to worry about quadrants ever again that way, and only takes about 10 mins extra work.
Old 03-01-2011 | 04:12 PM
5tox's Avatar
5tox
the one i have in it at the moment is white, and this new ones black...
my brother is still down at the car and having problems getting the old one out, he's going to remove it tonight and bring both back here so we can measure and see the difference
Old 03-01-2011 | 04:15 PM
5tox's Avatar
5tox
how much do you want for your white one mate?
ill take the old one back for a replacement but good to keep a spare i guess since it appears to be a common problem.
Old 03-01-2011 | 04:31 PM
5tox's Avatar
5tox
he has just got the old one out and says that they are completely different, also found quite a useful guide online 'QH technical partnership manual'
it pretty much sums up what dojj said above
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
arkeye
Ford Focus ST
20-02-2016 02:22 PM
