sierra cosworth 4x4 gearbox differances,early,late spec
i have 2 cosworth 4x4 gearboxes,both casings are the same measuring 78cm and 1,which i think is an early 1 (1991) measures 81.5cm from bellhousing to where the rubber prop doughnut bolts on.
the other,from a late 92 car measures 78cm also but 86cm from bellhousing to coupling.
are there any more variations in lengths over the 4x4 lifespan,are escort cosworths different again?
thanks,lee
thanks,lee
Two types
Early 4x4 Sapphire - Takes the thicker prop donut
Late Sapphire/Escort Cosworth - Takes the thinner prop donut.
All you need to change to make either fit the 'wrong' car is the donut and the front section of the rear prop.
jason_nike
18-08-2019 10:53 AM
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
