- torq settings please
- Ignition warning light on/off in Focus TDCi
- Focus gearbox leak
- engine oil rs turbo
- zetec conversion temp gauge
- Rear strut brace on a 4x4 saph
- 2wd brakes on to a 4x4
- Cosworth starting problem
- Carbon Fibre skinning
- RS Turbo Gearbox ? or not?
- converting servo to abs
- Removal of RST Gearbox
- Where can I buy a new heater matrix for my saph
- can i use a piper efi cam in an mfi head
- St170 power problem
- New Gearbox
- Electric Roof Pump Relays HELP
- Ford key with 3 button remote
- 180/60/13 on a ka? yes/no?
- Please help
- Fiesta ST starting problem
- external wastegate on manifold
- Which Head Gasket Thickness Do I Need (for Cosworth YB)?
- WAter pump on mk1 orion
- any from round tipton area....
- ECU/Transponder/Key Help - Where does it plug into? (Pics included)
- Alcon clutch
- roughly how much t3 turbo price
- wheels compatibilty
- Mondeo TDCi clutch pedal feel
- cosworth buggy help
- Clicking as I'm steering ?
- Cab Roof pump issues
- ST170 couple of niggles
- Ka brake upgrade - Pedal problem
- How long can an engine sit with oil in before its scrap?
- front camber problem
- Transmission help on a engine conversion!
- throttle postion sensor problem
- Connecting pectel t6
- cosworth fuel problem
- Transit help
- sub
- RS500/3dr center cap locks/bodge?
- Puma conversion help
- Is it true...
- transit speed limiter removal help
- Strange aircon blower issue
- mk3 rst rwd cossie yb
- car coughing?
- Ecos spluttering when i give put the boot?
- no drive on st200....
- rs turbo wont stay running
- dash warning display computer
- Type 9 upgrade to Cosworth T5
- i found a broken wire
- Escort RS Turbo Central Locking Problem
- Next problem
- Ford KA 5000
- 2001 focus water pump change q,s
- rs turbo MFi wont start
- 1.3 fiesta coil
- 1.8 zetec head vacuum
- Final Drive Change in ib5
- T Reg Focus Air Con/Fan fault
- Cosworth diff.
- 4x4 Sierra Cossie Steering Rack
- 6000 cd code help please
- mk3 mondeo 2001lx
- pug 206, help needed!!!
- Ford Bantam 1.3i Rocam Utility or "pickup" workshop manual
- Mondeo zetec oil pressure relief valve?????
- 16 cvh wont start when hot
- How to get a leak free cam cover and 1/2 moon seal
- head gasket problem
- starting issue
- Electrics, HELP.
- Ignition/Spark Timing...
- What turbo??? help!
- strange starting problem...
- my focus st 170 wont rev past 5000 rpm
- escort mk3 gearbox oil????
- Escort RS Cab project!
- Indicator wiring diagram?
- 3 pin MAP Sensor
- can anyone tell me what this chip is meant to run?
- rear beam how to tell if 4be or 2wd
- st170 engine & box into fiesta st150
- Had enough of it now
- 2wd Saph battery light
- Omex 710
- brake conversion
- Help with my tdci 130 mondeo
- head gasket?? crack??
- sapphire cosworth fuel system
- running problems
- help! mk2 1.8lx mondeo problem with acceleration!
- mondeo steering angle senor
- Identify the electrical sender
- New turbo
- help with fuel guage !
- Rst efi tapping
- st170 gearbox
- 3door cossy transplant
- Escort Cosworth 1993 ABS error
- T3 turbo
- rst piston size
- Even the man from ford parts said this was a stupid way of doing things!!!!!
- coil pack conversion
- ST170 MANI IN 2.0 ESP. Sensor question
- 2ltr twinky flat spot
- efi relay
- heating problems - an update?!
- original ford electric aerial
- Anti-Roll bar
- Which changer
- Efi.
- Wiring up Boost, oil & volt gauges
- Ford Mondeo loss of power @70mph
- rst metering head problem huhu
- Ford Focus Right Rear parking brake problem
- how do you remove the aux bearing from the yb block?
- New cosworth issue
- Painted engines
- Rear lights. dash illumination, fag lighter....Help!
- Mondeo Dipped lights
- MPG cant be right?
- mtech v4 ecu
- Mondeo Mk3 remote locking
- HELP 2wd cos drop links
- Cossie:Low fuel pressure effects boost?
- CVH Dipstick tube Seal
- P100 Sierra gearbox swap?
- Smoking zetec
- focus 1.8 cheap power?
- brake bleed nipples
- Escort Van n/a to turbo??
- 2wd dizzy problems
- Ford focus radio.
- focus st help
- 406 Auto judder at idle
- Steering Problem - Mk1.5 Focus 1.6 Zetec
- ring luminator3 spotlights need advice
- Few performance questions Focus 2.0
- T4 on a 4x4 manifold?
- Mk 4 escort 1.3 eclipse exhaust splutter
- battery light is on but i have had the alternator changed!
- 2.0 focus c/r ratio
- mk4 zetec alot of cunfusion
- cosworth ecu ?
- Central locking/Electric Windows Mk4 Escort/Mk2 orion
- nailing it and blue
- Cheap Decomp Plates
- HELP someone gotta know??
- The connection between ECU (Cosworth L6) and Pinto EFI
- just gone and looked at this
- ford sierra 2,8 mfi problem
- Deceleration fuel cut settings OMEX
- Saph fog lights
- Wheel wobble on full lock - Sierra
- Sound deadening removal!
- Turbo
- Focus 1.8TDCI Turbo problem
- Cosworth breather systems explained
- Ofac 6 pin plug to focus
- ka reving when clutch is down
- MPG help on my 2001 Focus
- ST170 Sump Plug Size
- Cossie boost problem
- Focus ST Mk2 GT30R ESP Fault
- Rebuilding calipers - How and where?
- ECU and remapping.
- Cossie has the hiccup!
- cvh blocks
- indicators
- Efi turbo
- Dashboard backlighting .
- RS Turbo EFI Cylinder Heads
- fse power boost valve
- diff ratio
- duratec 2.0 st170 wont start
- Ka 1.3 Duratec overheating
- ecu help
- Carb Tuners
- Auto Gearbox Problem
- mk3 escort zetec conversion ,rev counter??
- T25 rebuild
- Cosworth drive shafts
- Zetec MAF Wiring
- endura tddi finding tdc
- Mk6 escort rear van shocks?
- will standard piston rings for cvh fit on 1650cc pistons ?
- cut out switch
- Escort rs turbo brake caliper question..
- RS TURBO mk1 C600 HLG
- ERST 2 Pace Single Pass Intercooler fitting instructions
- Sapphire Cosworth flat spot when cold
- my 2001 focus radiator fan is always on and the radiator is stone cold help please.!!
- Cosworth pistons
- missfire on n/a zvh on r1 carbs
- zetec conversion
- clutchhh!
- 98 mondeo 2.0 water problems
- Focus vs Subaru....Advice needed!
- largest disc
- Not HCV, could it be the matrix?
- What engine transplant...
- Tolerance For Pistons & Pins 86mm Rebore Zetec
- S2 abs removal
- Twin 40's on 2.0 Zetec Help!!!!
- Need some good advice on what to do with this.
- stud conversion
- changing the radiator on a celica GT (P Reg)
- Piston rock at tdc
- camshaft and flywheel upgrades
- focus not starting
- ecu decoding
- Saph petrol
- Focus v6?
- Four saperate coils to rs2k?
- is there a specific order to tighten the bolts on a xr3i sump?
- Where i can buy I need help: top seals and grease for GRA Cosworth Bilstein Dampers
- Gartrac Ecort rwd running issues
- Mods on p8 to read data stream
- Engine Pinking!!!
- 1.8 black top turbo help ???
- st170 rotrex charger omex kit car conversion alternator query
- Axle spacers
- Air con knocks off at blower setting 2
- Can oil find its way past a manifold gasket?
- Focus 1.8 Which Battery
- FRS MK1 Whirring sound.
- ford galaxy mark 1
- ST220 Power loss
- Ford focus 2001 enduro di pump
- Do I need a heatshield?
- EDIS EEC IV No spark.Help.....!!!!
- urgent help
- mondeo tdci
- Mondeo TDCi 2006 fuel metering control fault
- Sierra Saph 2wd - replacing fuel pump with 044
- crank bearings
- Ford KA 1.3 collection 54 reg Fault codes
- Turbo differences T3 / T4 / T34
- alternator wiring issues please all help me!
- MK2 Granada engine swap
- Need someone to inspect there ST170 engine!
- mondeo 2006 TDCi -injector pump fuel metering control fault Help!
- Breather system advice- blacktop ZT
- 1999 Ford Focus won't start....
