Alcon clutch
Old Jul 20, 2011 | 10:43 AM
shortie's Avatar
shortie
Default Alcon clutch
Ive had this fitted for about 3 months done 450 miles now it has started juddering & the car is stalling when i pull away, has anybody had the same issues with an alcon
Old Jul 20, 2011 | 10:45 PM
Dezzer's Avatar
Dezzer
4x4 resto
Is it a paddle clutch mate , if so 4 or 6 paddle ?
Old Jul 21, 2011 | 10:43 AM
shortie's Avatar
shortie
Yea it's a 6 paddle matey
Old Jul 21, 2011 | 03:47 PM
They are as I found incredibly touchy when new, the height difference in the clutch pedal between starting to bite and fully bit is so small,(try it with a much lighter flywheel like I use even better!!) but it does get better, well mine is, there's defo a knack to getting it right that's for sure.
Old Jul 21, 2011 | 04:57 PM
2wd's Avatar
2wd
I have now used the 6paddle Alcon setup for 2 years and just over 10K km and I find it fine and will replace it with the same when that time comes !
....only down side is that I find that I have to put on a little more rpm when starting, and occasionally there is just a little "judder" at that point .. other than that I find it fine .. no slip as on the uprated AP organic one I had before
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
