my focus st 170 wont rev past 5000 rpm
Hi my st 170 wont rev past 5000 rpm it just stutters like its hitting a rev limiter and pops and backfires i have put a de cat on it no cure, changed plugs, oil,air filter, oil filter, fuel filter, no cure, now i am totally baffled! any help would be mutch apprieceated!, Thanks in advance
st 170 power problems
Hi guys thanks for the replies, Yeah my rev counter is defo working because the car ran fine for a few days then started doin it again making me think its some sensor. And when the car is properley warmed up sometimes it wont even rev past 3000 rpm. Really annoying!. And the car also feels like its lacking power before it even starts juddering and poping
Hi guys thanks again for the replies no i have no engine management light on. My first thaught was the fuel pump but when it ran good for a few days that made me think it was a sensor. But when i go fast around a roundabout or corner it dies and judders untill i lift off the throttle. Theres a few things i can think of but i am not wanting to throw money at it hoping to cure it.
Hi i checked the inlet manifold runner control today the cable is pulled when started like it should. But i noticed that when the engine is turned off you hear air de compressing from some where a hissing for about 5 seconds is that normal?. Also when you turn your ignition on should the engine management light light up for a few seconds then go out again?. Because mines doesent. Any help would be mutch apprieceated. Thanks again
Ok thanks right diving to and from work today and the car wouldent rev past 3000 rpm it would reatch 3000 rpm then judder vilantley and eventually when i put my foot to the floor the car got all choked up and would die. But if i accelerated a little gradully the revs would go higher then whilst stationery it wouldent rev past 4000 rpm never used to do that then it died and when i tried to start it the engine would just shake and judder sitting below 1000 rpm and would not rev when i accelerated it would die. Please help me Thanks
st70 build underway
al
Hi all pluged in a code reader today and im geting the fault code p0141 for o2 lambda sensor bank 1 sensor 2 whitch one is this? the pre cat sensor or the post cat sensor? the first or second?. Also do you think that a faulty lambda would create this problem? Thanks in advance
P0141 O2 Sensor Heater Circuit Bank 1 Sensor 2
Sensor 2 is the post cat sensor. If you have more than one post cat sensor, then this is the one in the exhaust from cylinder 1.
Check wiring if 12 volt is present for the heater.
Post cat sensor only measures if the cat is still working. It has nothing to do with the engine splutter.
st 170 fault code p0141
Ok mate thanks do you think i could be geting this code because i have a de cat?. And are you saying you dont think a new lambda sensor will cure it? cheers Ewan
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
