S2 abs removal
Old Jun 16, 2011 | 06:50 AM
robrs666's Avatar
robrs666
Default S2 abs removal
Hi everyone my engine and box is out so I thought might as well get rid of the poss poor abs setup so I have removed the fluid res
The abs units (silly round things)
All the joining pipe work
So I'm left with
A T peice on each inner wing
1 outlet on each goes to flex pipe for caliper
2 outlet on each along bulkhead then runs towards back of the car down drivers side
So I'm left with a open outlet on each T peice I gather the new lines from master cylinder goes go each one of these outlets is
that right I'm sure it has to be but want to double check
Many thanks guys
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
